How many times can you re-use cam plugs if at all?
10 May 2016 13:12 - 10 May 2016 13:13 #725552 by 750Kruzer
just occurred to me If I had any internal work done, would the cam plugs be able to be re- used as I think mine seem to have that silver gasket seal on them and I've seen others that have the gasket seal applied to them as well.
1983 KZ750 LTD Twin K1
Last edit: 10 May 2016 13:13 by 750Kruzer.
  • SWest
  • 10 22 2014
10 May 2016 13:19 #725554 by SWest
I've reused mine for years with copper silicon. Went to solid aluminum in 87.
The following user(s) said Thank You: 750Kruzer
10 May 2016 13:27 #725557 by 750Kruzer
thats good to know. Thanks
10 May 2016 13:43 #725562 by KZB2 650
Be sure to keep em in order..... I do every thing but planned on replacing these so I didn't and have one or two not quite right.......
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
10 May 2016 13:54 - 10 May 2016 13:58 #725565 by 750Kruzer
makes sense given it is recommended to re-install most all bolts, that I'm aware of, to their original location as well as the cam hold down collars (?) Don't know their proper name but you know what I'm talking about. Parts get worn-into their particular location or are put there at the factory for a reason- because they are machined from the same piece/fit together
KZB2 650 wrote: Be sure to keep em in order..... I do every thing but planned on replacing these so I didn't and have one or two not quite right.......
Last edit: 10 May 2016 13:58 by 750Kruzer.
  • SWest
  • 10 22 2014
10 May 2016 13:57 #725566 by SWest
Mine were so old and hard, I knew I needed to replace them. The billet ones were a lot cheaper and permanent.
10 May 2016 21:08 #725644 by RonKZ650
My experience is if they leak, replace them. If removed, replace them. Sealer never holds long and leaks will come quickly. Others report better results though. If I I remove one for any reason, or if one leaks, they go in the trash. 40 years nearly with these bikes for me and I've tried the options.
11 May 2016 16:13 #725819 by jdvorchak
swest wrote: Mine were so old and hard, I knew I needed to replace them. The billet ones were a lot cheaper and permanent.
Any help in finding the billet ones online would be appreciated. I have the valve cover off my KZ1100 right now doing the valve lash. I will need cam plugs and gaskets.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • SWest
  • 10 22 2014
11 May 2016 16:15 - 11 May 2016 16:17 #725821 by SWest
No eBay APP ID and/or Cert ID defined in Kunena configurationZ1E should have them. Mine are the early style. Yours has the bolt in them?
Last edit: 11 May 2016 16:17 by SWest. Reason: add link
  • SWest
  • 10 22 2014
11 May 2016 16:20 #725822 by SWest
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
11 May 2016 19:18 #725860 by jdvorchak
12 May 2016 15:40 #726019 by 750Kruzer
heres how mine look:
