cam install
- kayodash
Re: cam install
12 May 2016 12:15
oh, this is a different bike. the pictures are on the 550. that one is good for now. everything lines up nice. I'm working on the 750 now. ( I should've started a different thread ) ill snap a few pictures of the 750 tonight when I get home from work.
1984 Kawasaki KZ550 LTD F2
1981 Kawasaki KZ750 LTD
- kayodash
Re: cam install
12 May 2016 17:09
Ok I've got some pictures this post is the 750. They are the intake, and exhaust cam sprockets. Lined up with the paint mark on the letter T. My next post will have the marks lined up with the actual line
- kayodash
Re: cam install
12 May 2016 17:10
These are the sprockets lined up with the tdc mark.
- loudhvx
Re: cam install
13 May 2016 05:31
That exhaust cam looks pretty good to me, at least not enough to worry about. Like in the 550, the intake mark won't line up until the chain is pressed down in the middle. I am not familiar with the timing marks on the 750, though, so I don't know what to look for on the intake. I assume you have the correct mark on the exhaust side.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kayodash
Re: cam install
13 May 2016 07:39
ok, cool. tonight ill pop it off, get the shims and just realign to the proper marks. it didnt look like a huge difference between the two. so ill stick to what i know. and not try anything silly. its funny, on the 550 the intake are tight. on the 750 the exhaust are tight. oh well.
- kayodash
Re: cam install
16 May 2016 09:33
well guys ive got both bikes back together. just have to sync the carbs on both. and hopefully we'll be rocking!
