1984 KZ440 smoking black from right cylinder.
- BornAgainBiker
09 May 2016 15:52
Hi All,
Just wanted to get a little insight into the possible causes for my 1984 KZ440 smoking black from the right cylinder. The left cylinder spark plug is running a nice tan colour and the right one is running black and sooty.
Here is what I have done so far: cleaned carbs and set float levels to spec, set valves to spec, replaced plug wires, plugs and caps, tried swapping plug wires, but the right side still smokes and the left side still runs clean--so I don't suspect the coil.
Any insight you good folks could offer would be greatly appreciated.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- Nebr_Rex
Re: 1984 KZ440 smoking black from right cylinder.
09 May 2016 17:13
Choke butterfly or idle circuit.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: BornAgainBiker
- BornAgainBiker
09 May 2016 18:04
Pretty sure the choke butterfly is OK, but I will take a look at the idle circuit. Thanks for the suggestion.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- punisher11b
10 May 2016 00:12 - 10 May 2016 00:18
Are you burning any oil at all? is it a significant amount of smoke or just a small amount? Does the engine temp make a difference? Found out the hard way my bike is leaking oil past the valves when it gets good and warm. Ended up overheating my engine a bit from low oil now the valves are leaking a bunch. Went from a little to a lot of black smoke but all from leaking past the valve guide seals. Initially I couldn't even tell it was burning oil until I did a 200 mile continuous stent and lost a bunch of oil over time . The primarily leaking cylinder spark plug looked black and suit covered while the other looked nice and peanut butter colored initially as well. Bike ran great, wouldn't have known it was even burning oil . I just thought it was rich on one cylinder until I really ran it hard for an extended period.
- good luck
Last edit: 10 May 2016 00:18 by punisher11b.
- BornAgainBiker
10 May 2016 13:42
Doesn't seem to be burning oil and the black smoke is just a puff here and there, especially on a throttle blip. Before I cleaned the carbs it was running a little sooty on both cylinders, which makes me think it has more to do with the air/fuel mixture. But thanks for the heads up--I will keep an eye on the oil level.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- BornAgainBiker
19 May 2016 05:00A special thanks to Nebr_Rex for putting me on the right track. When I cleaned the carbs I somehow overlooled the idle air screws. When I checked the air screws, sure enough, the one in the right carb had a lot of deposits on the air screw needle. After cleaning the air screw needles, the bike runs great.Nebr_Rex wrote: Choke butterfly or idle circuit.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
