1976 KZ900 Dynamo cover oil leak
  • old-school
  • old-school's Avatar Topic Author
09 May 2016 04:45
#725283
What is the best way to stop a Dynamo cover from leaking ? It seems to be leaking from within the wires coming out it. I tried to use silicon within the wires but it still leaks some.
Thanks
(2) 76 KZ900s, 81 CSR1000 and 81 GPZ1100
  • TexasKZ
  • TexasKZ's Avatar
Re: 1976 KZ900 Dynamo cover oil leak
09 May 2016 05:12
#725286
You can replace the rubber grommet, though that generally involves cutting and splicing the wires that go t hrough it. A little dab of Three Bond on the back side where the wires go through is cheap insurance.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 May 2016 05:16
#725288
You can buy a new rubber grommet. You'll need to splice the wires and I use crazy glue on the woven covers on the yellow wires to make sure they seal. Z1E has them.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 May 2016 06:43 - 09 May 2016 06:44
#725299
It's pretty common for it to leak there. I believe the cloth on the wires wicks the oil out or there isn't a good bond with the grommet and wires. I sealed mine 5-6 years ago and hasn't leaked yet. I removed the cover and cleaned the snot out of the wires/grommet area using brake clean. I'd let it completely dry, then clean again. I did this about 6 times until there was no traces of oil on the wiring or grommet area. I used liquid gasket and let it seep into the cloth of the wires and pool on top of the grommet. Also filled in the cavity just below the grommet with silicone and sealed the grommet to the aluminum. Let it dry in the bench for a coupla days before reinstalling.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 09 May 2016 06:44 by Kidkawie.
  • old-school
09 May 2016 17:56
#725429
I will take it apart here in a couple of weeks and do what you recommended.
Thanks again
  • missionkz
  • missionkz's Avatar
23 May 2016 11:45
#728028
Mine has dripped from there for over 20 years now... I've had a new grommet for years, ... maybe I'll be ambitious and fix it some day... LOL.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
23 May 2016 12:15 - 23 May 2016 12:24
#728037
. It leaked for ever until I got it all together I splice mine by redoing my plug with a tool and new ends on the 3 wires to the stater. Repull the sock and all. I hate cut and soldered and shrink boot, its just not as neat.
Last edit: 23 May 2016 12:24 by 9er rider.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2016 12:24
#728038
I got tired of oil on my one boot. :dry:
