lowering compression
  • PaintWorkz
  • PaintWorkz's Avatar
Re: lowering compression
28 Apr 2016 06:51
#723413
Cometic makes the best gaskets out there. They are made to order with at least 6 different thicknesses to choose from.
How do you know what your CR actually is? A 1200cc with a larger than stock dome is probably going to be more than 10.5 : 1. The larger displacement raises the CR up big time. Best to talk to your piston manufacturer and they can explain all this. A 1200cc block would have big liners so it was probably resurfaced and that is like installing thinner head gaskets.
Best to find someone with a Whistler and see what your CR currently is, that is the easiest method to get a true CR.
Things like sharp edges on the valve pockets can cause detonation, best to tootsie roll any sharp edges off the domes.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • DFIGPZ
  • DFIGPZ's Avatar
28 Apr 2016 13:12
#723491
the only way to know your CR measure piston dome volume, piston deck height, head gskt thickness, cc cylinder head DO NOT go by CR listed by piston company are your cams degreed ? head gasket the correct one [ not hanging in cylinder } lot of different things can create detonation is timing set at 38 deg ? stacking base gaskets and thick paper base gaskets you are asking for trouble.
1984 750 Turbo
The following user(s) said Thank You: PLUMMEN
  • baldy110
  • baldy110's Avatar
28 Apr 2016 14:04
#723501
DFIGPZ wrote: the only way to know your CR measure piston dome volume, piston deck height, head gskt thickness, cc cylinder head DO NOT go by CR listed by piston company are your cams degreed ? head gasket the correct one [ not hanging in cylinder } lot of different things can create detonation is timing set at 38 deg ? stacking base gaskets and thick paper base gaskets you are asking for trouble.
+1, you shouldn't be having any detonation issues with your setup. Are you 100% the ignition timing is correct along with your jetting. I had a huge hole between 3000 and 3500 rpms. It turned out to be the ignition advancer springs. I did the same thing you did tighten them up, that actually created the hole. I bought a bunch of used ones and everyone of them did the same thing big hole between 3000 and 3500 rpms. I finally ponied up the $90.00 and bought a new advancer with springs and installed it, solved my problem. I left the springs alone and used them as is.
The following user(s) said Thank You: larslykkegaard
  • PaintWorkz
28 Apr 2016 14:42
#723509
A simpler way to measure CR is finding a shop that has a Whistler..... store.katechengines.com/whistler-compres...tio-tester-p174.aspx
To lower CR you are not asking for trouble if you use Cometic paper and aluminum base gasket set up.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • DFIGPZ
  • DFIGPZ's Avatar
28 Apr 2016 16:01
#723518
Cranking Compression And Compression ratio 2 complete different things aluminum base gasket is fine but stacking paper or thick paper base gaskets are trouble but hey do what you will :unsure:
1984 750 Turbo
  • DGA
  • DGA's Avatar
28 Apr 2016 17:57
#723539
Lean mixtures will make a motor detonate. Sure you aren't lean on the bottom end? The more power an engine makes, the more fuel it needs, if you have improved it a lot it could just need more fuel. Plug gaps are a good way to fine tune spark timing, wider gaps start the burn over a larger area and detonation can come on sooner, Try reducing plug gaps a little.
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
  • PLUMMEN
  • PLUMMEN's Avatar
28 Apr 2016 22:21
#723570
The number they advertise for the compression ratio of the pistons is just a way to sell pistons to stary eyed gear heads! :woohoo:
You want to know the actual cylinder pressure which is affected by things like decking the head or cylinder cam lift/duration/timing.Thats where horsepower is actually made/lost,not so much from fancy bumps on pistons.
  • larslykkegaard
  • larslykkegaard's Avatar Topic Author
28 Apr 2016 23:34 - 28 Apr 2016 23:42
#723574
Here's one of the first dyno run from a picture on my phone - was aming for around 12,5 on the A/F (25%-50%and 100% throttle) and got a bit closer than this
Also tried with old advance springs and play with the ignition a lot
cams are timed as specs (K410)
Carbs are Mikuni WM33 which have been renovated at Mikuni/Topham
SO if to lower it people would put a alu or copper base gasket???
Attachment IMG_5750.JPG not found
Last edit: 28 Apr 2016 23:42 by larslykkegaard.
  • larslykkegaard
28 Apr 2016 23:44
#723575
one of the last with 50% and 100% throttle
Attachment IMG_5748.JPG not found
  • PaintWorkz
29 Apr 2016 05:28
#723586
Cranking Compression (pressure) and CR are different but related. CR goes up and cranking pressure will go up. A Whistler tells you CR, not cranking pressure.
Lars ....call Cometic and talk to them about their base gaskets.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • DFIGPZ
  • DFIGPZ's Avatar
29 Apr 2016 13:08
#723634
I am done way to many people in this what do i know I have only put hundreds of KZ Engines together from stockers to Drag motors that are 16.1 CR and lived its no wonder why good people like Larry do not want to get involved so you key board punchers have at it. :whistle:
1984 750 Turbo
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 May 2016 06:52
#724237
