- Thank you received: 1
lowering compression
- larslykkegaard
25 Apr 2016 00:40 #722810
by larslykkegaard
lowering compression was created by larslykkegaard
Anyone having knowldge in the compression ratio??
Im running a 1197cc/76mm but wanna lower the compression - anyone knows approx how much what, will give??
EG. 1mm ticker gasket gives around 0.5 ???? from 1: 10.5 to 10....???
just a rougly idea where to start
/Lars
/Lars
- PLUMMEN
- Thank you received: 104
25 Apr 2016 02:27 #722813
by PLUMMEN
Replied by PLUMMEN on topic lowering compression
What pistons /head are you using,how much are you trying to lower it? Has the head or block been milled/how much?
- larslykkegaard
25 Apr 2016 02:48 #722815
by larslykkegaard
Replied by larslykkegaard on topic lowering compression
The head is a stock lz1000a head with stage 1 done by joe/PSP
yes the cylinder top and head has been planned
i know i cant have anything direktly but just a guide line
Pistons is from a company called REC-tuning in germany (horrible service) -ordered to be around 1:10.3-5 compared to Wiseco's 10.25
- KZB2 650
- Thank you received: 265
25 Apr 2016 06:01 #722831
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic lowering compression
I've read that on a 810 kit for a 650 every .010 cut on the head will pick you up approx 2 tenths of a point...... totally diff animal I know so maybe I should stay outta it........ I've also read that checking the cc's (volume) of the head and piston is really the way to know for sure what you have...... and one more use less hear say I've read that Wiseco's are slightly less in comp than they state also.(why a head cut is recommended on the 650/810 build.
1978 KZ650 b-2
The following user(s) said Thank You: larslykkegaard
- baldy110
- Thank you received: 512
26 Apr 2016 10:10 #723063
by baldy110
Replied by baldy110 on topic lowering compression
What are you trying to achieve here? I run 10.5-1 compression pistons on most of my bikes with no issues. I could see lowering the compression if I had detonation or other cylinder issues but if you have no running issues then why go through the trouble?
- larslykkegaard
27 Apr 2016 01:23 #723193
by larslykkegaard
Yes i have small detonation on the low rpm
- Thank you received: 2829
27 Apr 2016 05:08 #723196
by 650ed
Replied by 650ed on topic lowering compression
Have you tried using high octane fuel and retarding the ignition timing a bit? Ed
- zukdave
- Thank you received: 229
27 Apr 2016 17:17 - 27 Apr 2016 17:21 #723324
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic lowering compression
My ZX750 motor has a Wiseco 10.25 comp. 810 kit with about 010 off the head and in will
run fine on 93 octane pump gas if it's not 100 degree's out and I don't pound on it's ass.
I do have an advantage over most on here as most have a stock ign. advancer
with my Dyna 2000 ign.. box I can plug in the laptop and program a timing curve
and set the adv. degree's every 100 rpm from idle to 16,000 rpm.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 27 Apr 2016 17:21 by zukdave.
- PaintWorkz
27 Apr 2016 17:27 #723325
by PaintWorkz
www.paintworkz.com
84 Gpz900 street
77 KZ 1325 Turbo Dragbike project
79 CBX Pro Stock projects (2)
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
Replied by PaintWorkz on topic lowering compression
IIRC.....Mr.Turbo said on a 1015 an extra base gasket would lower the CR 0.2 or was it 0.5
There should be a formula to figure that out somewhere
www.paintworkz.com
84 Gpz900 street
- zukdave
27 Apr 2016 17:42 #723329
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Stacking base gasket's work's but tend to leak but I bet Cometic would
make a thick one if you called and asked.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- missionkz
27 Apr 2016 22:22 #723374
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic lowering compression
Hmmmm. I don't think you should be having any detonation or pinging with any 10.25:1 engine, correct ignition timing and +91 octane.
Something is wrong.
Something is wrong.
Bruce
1977 KZ1000A1
- larslykkegaard
28 Apr 2016 01:10 #723385
by larslykkegaard
Well i have always been running on 99octan/v-power and sometimes with boost. The ignition is a DynaS and the springs on the advancer has been tighten to 'hold' the ignition a bit. It has the green 3ohm dyna coils and tayler plugs. Cams are K410 timed to their standards. Head has been done by PSP. and the guy who help me run it on the Dyno is a guru around this (MJP)
it has a 'hole' around 3000rpm and at 3500 the curve rises like a wall ending at around 10k rpm and 120Whp
MJP said i should change the exhasut a tiny bit to get rid of the 'hole' 3000rpm - i did and it helped, but it still has a tiny bit of detonation around the 1500-3000rpm
Only thing that actually help a little bit was iridium sparks!?!?!
the things is the guy who did the pistons wanted me to run with CNC fitted GPZ1100UT headgasket due to he said that the Cometic was crap.. I can see the UT headgaket is slightly thinner than the fiber version...
I didnt do a compression measure do to it 'only' was a street engine where i ordered the pistons not to be to agresive (10.3-5) and with a 'mild' version cam
I know that cylinder and head hight is a big play in this game, same as how deep the valves are in the seat and all those things (the cylinder was taken of a stock runing bike and the head Joe found me)
but but
but but
