KZ1000 headgasket
- larslykkegaard
KZ1000 headgasket
25 Apr 2016 00:35
I need to change my headgasket on a KZ1000 - 1197cc/76mm
When using a 1.pc copper headgasket do you still use the rubberselling o-ring around the camchain???
Ive been running with a 2.pc GPZ1100UT (machined to 76mm) but thats not an option anymore
/Lars
/Lars
- PLUMMEN
Re: KZ1000 headgasket
25 Apr 2016 02:29
Dont use a copper head gasket unless the block has been o-ringed around the sleeves,otherwise it will leak like a sieve.
The following user(s) said Thank You: larslykkegaard
- larslykkegaard
25 Apr 2016 02:50
damn - what do you recommend then for 74mm - heard the fiber from Cometic is crap so thought the copper one would do (without oring the sleves)
25 Apr 2016 07:47
I'm using the Cometic one piece. Works great. Just filled the O ring space with silicon and put it together wet. No leaks. Copper gaskets have been used for as long as I can remember without leaks. The fiber gasket was cheaper and it is the second of it's type I've used. The first was a early Z1 that was a little smaller that the bore. (no problems) This one is for a 72mm and is on my 70mm bores. NO LEAKS.
- PLUMMEN
25 Apr 2016 11:13
The copper gaskets are soft,theyre made to compress down around the o rings in the cylinders to help them seal.
Their main advantage is they can be anealed and re used over and over,which is a good thing for a drag bike that gets torn down a lot.
