Random idle misfire after rebuild
  • shamal
  • shamal's Avatar Topic Author
Re: Random idle misfire after rebuild
27 Apr 2016 11:00
#723261
yes, it seems fine.
today i put a look again on the timing gun. with 1/4 spark plugs she seems good to me. in the 2/3 coil i have a ''blackout'' that i can definitely see without risk of being wrong.
i'm sure the light go off.
the bike keep idling with her usual misfire.
TWo qestion:
1 - since the pickup coil is replaced and ok, the real question is... can be the IC igniter also? in the next days i will receive the new coils... i really hope for the best.. igniters are expansive!
2- in your experience, can a faulty coil/ignition make the engine sound more noisy than normal? sometimes like a knocking? or some others kind of wierd noises?
1983 kz 550 h
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Apr 2016 11:10
#723265
Yes. What OHM coils did you order?
The following user(s) said Thank You: shamal
  • shamal
27 Apr 2016 11:13
#723267
direct replica replacement, visually identically to original zc006 tr12V i have from factory.
you mean yes about noises?
and another thing .. i think this bike have to be more powerful under load... coils again?
1983 kz 550 h
  • shamal
27 Apr 2016 11:26
#723274
1983 kz 550 h
  • shamal
06 May 2016 13:05 - 06 May 2016 13:07
#724922
New coils and wires, no more misfires...
This changed alot: when i release the clutch i almost dont need to open the throttle, alot of power since 1500 rpm, better acceleration, better throttle response, more powerful under load, and no more engine braking during deceleration.
Yess.. :)
Engine had only 80 miles since i rebuild it, it is good. I hear alot of noise from the pods.. But i think this is normal..
1983 kz 550 h
Last edit: 06 May 2016 13:07 by shamal.
