Random idle misfire after rebuild
24 Apr 2016 10:25 #722673 by shamal
Random idle misfire after rebuild was created by shamal
I did a total engine rebuild. New rings, cylinders honed , valves job , new oil seals everywhere, new camchain, head lapped, new gaskets. Good compression, carb rebuild too. New nos intake boots.
Engine is running perfect with new foam pods.
Mid range perfect.
Wot operation perfect, acceleration is good, she can easily reach 70 mph flying through the gears
Cold and hot starting are normal.
The bike idle well, 1100/1200 rpm.
BUT WHEN IS HOT after a 3 or 4 miles she start to misfire ,only when idling , for just a second.
It is Like a ... "Brrrrrrrr-TUMP-brrrrrr-TUMP...." LIKE 1 or 2 cylinder loss power for just a second.
I tested my ignition coils with a hairdryier and i have always 3ohm primary and 12.90 ohm secondari.. In both coils.
I swapped the IC igniter no luck.
I saw i have a broken magnet in the pulser coil. It is possibile this kind of issue due to this magnet?
Any help will be very apprecciated.
1983 kz 550 h
24 Apr 2016 10:27 #722675 by shamal
Replied by shamal on topic Random idle misfire after rebuild
I forget to mention carbs are synched and i have new spark plug cap 5kohm , new no-resistor HT leads, and new ngk D8ea...
1983 kz 550 h
24 Apr 2016 10:30 #722676 by 650ed
Replied by 650ed on topic Random idle misfire after rebuild
You also forgot to mention what kind of motorcycle you are talking about. PLEASE add the bike's year and exact model to your signature line. That way you don't need to remember to put that info in the text of every posting. Ed
24 Apr 2016 10:33 - 24 Apr 2016 10:39 #722677 by shamal
Uhuh, your right ed. I talk about a 1983 KZ 550 H
Gpz unitrack. The one in my avatar.
I had this issue even before engine and carb rebuild.
I was thinking about dyna but honestly it is really too expansive....
Im searching for a good used pulser coil, IF this can be the cause of my issue.. I'm really Not sure about
1983 kz 550 h
Last edit: 24 Apr 2016 10:39 by shamal.
  • The_Proletariat
  • "Cocaine is a hell of a drug"
24 Apr 2016 10:39 #722680 by The_Proletariat
Replied by The_Proletariat on topic Random idle misfire after rebuild
Mine has done this as well. Have never been able to figure it out.
1982 Kawasaki KZ550 LTD
24 Apr 2016 10:40 #722682 by shamal
The_Proletariat wrote: Mine has done this as well. Have never been able to figure it out.
You tryed with new ignition components?
1983 kz 550 h
  • The_Proletariat
24 Apr 2016 11:56 #722693 by The_Proletariat
Yes. Dyna S and 3 ohm coils. I've never had a good idle under 1400 or 1500 rpm.
Been through carbs, ign, and valve clearances and could not figure it out so I gave up. I will be watching this thread to see if there is any resolution.
24 Apr 2016 12:42 #722700 by shamal
I have a steady 1100 or 1200 idle.. This is the strangest thing. I have a perfect engine that when warmed up properly start to miss one or more spark, or at least i think about spark..
I cant figure out this thing. I think i can say it is Not mechanical. Engine is quiete, all new componenti except ignition system.
I really dont inderstand the function of the magnets in the pickup coil and if that cracked magnet can be the cause.
If you had the same issue even with dyna .....i think im lost.
1983 kz 550 h
24 Apr 2016 12:55 - 24 Apr 2016 12:57 #722703 by bountyhunter
Replied by bountyhunter on topic Random idle misfire after rebuild
shamal wrote: The bike idle well, 1100/1200 rpm.
Hot misfire is usually a coil. bench tests can never find flaky coils.
Valve clearance on target?
Last edit: 24 Apr 2016 12:57 by bountyhunter.
24 Apr 2016 12:59 #722704 by 650ed
You may want to try this...
When the engine is still cold and running with no misfires use a hair dryer or other tool to warm up one of the coils. If the engine then misfires, that coil is suspect. If not, heat up the other coil to see if that causes the misfire. Ed
24 Apr 2016 13:04 #722705 by pete greek1
Replied by pete greek1 on topic Random idle misfire after rebuild
650ed wrote: You may want to try this...
Ed, he said he did that in his 1st. post,
Pete
24 Apr 2016 13:14 #722706 by 650ed
DOH! :blush: Ed
