Throttle issue
- T0ink
Throttle issue
17 Apr 2016 14:49
I got my bike out finally, new tires, made sure the carbs were clean, lubed her up, all set to go! Get on her to top off the tank, and I notice that when I i let off the throttle it kind of... Lags? Lurches? It feels like when you downshift. Doesn't matter how fast I'm going, 20 around the block, or 60 on the highway, if I ease or let go of the throttle. Any suggestions?
81 KZ750 LTD
81 KZ750 LTD
1981 Kawasaki KZ750 LTD
Rockford, IL
Rockford, IL
Re: Throttle issue
17 Apr 2016 16:33
Check your spark advance. Also the diaphragms.
Re: Throttle issue
17 Apr 2016 23:34
Would also check for air leaks in the carb holders.
- T0ink
Re: Throttle issue
18 Apr 2016 07:27
Thanks for the starting points! I'll take a look when I get home and let you know what I find
Rockford, IL
Rockford, IL
- MDZ1rider
Re: Throttle issue
18 Apr 2016 09:12
2nd on Patton's suggestion of air leaks in the card holders. You said made sure the carbs were clean. If you removed them for the cleaning that's even more reason to suspect a bad seal at the holder. A common trouble shooting technique is to spray WD-40, propane or starter fluid at the carb/mount junction. If the RPM's change (up or down depending upon what you use), you've got a air leak. If your holders are original, they're probably hard and due for replacement anyway.
