oil issues
Re: oil issues
18 Apr 2016 15:32
I take it No Manual. :dry:
- goldylox
Re: oil issues
18 Apr 2016 16:06
Yea no manual ill go get one but and there are two lines on my sight glass and i put it a lil over the top but i took it out yesterday and there was no leakeage but i also wasnt going fast either but i realy do need to go threw the motor and get all seals replaces and anything that looks worn any referals in the missouri area
- pete greek1
Re: oil issues
18 Apr 2016 16:13+1 , exactlyKZB2 650 wrote:
Do you see the little round filter (that is sticking straight up) that is under the carb filters ..... (in the middle of Pete's motor) ..... is that where you are talking?
I got a little and a lot of ribbing from Steve and Patton about using one of these filters in a similar thread and am glad to see your running one Pete.
You say you think you put too much oil in...... put the bike on the stand or have some one hold it level and check the sight glass... if its above the top drain a little till you get it in the middle.......if after you get the level to this point and its still spitting out a lot out of this port like Steve says you have more problems maybe a broken ring or another cause of pressure build up.
