Oil pump
- G-Force
Oil pump
15 Apr 2016 18:33
Hi all,I have a 83 kz750 l3.Did a oil pressure test and gauge didn't even move so we thought the gauge was bad and disconnected gauge and turned engine over,no oil came out.The mechanic helping wrenched at kawa in 70s and 80s.He said oil pump / pressure release valve or blockage of oil passage. I removed oil pan the pressure release was not stuck open or closed.The oil pump appears to function OK,did not inspect inside of pump.I held hand over pump screen and with help turned engine over(plug wires off).I could feel some very slight suction.Is there a better way to test pump I know I can check tolerance between pump rotors .How much suction should be felt?oh forgot to mention,this is a fresh top end and the oil light stays on.No problem before rebuild but did find some little rocks in oil pan I'm guessing rocks were around studs,and fell in during disassemble.
Re: Oil pump
15 Apr 2016 18:42
Take the plate off the pump and inspect it.
- missionkz
Re: Oil pump
15 Apr 2016 21:50
And maybe polish it with very very fine wet-dry paper.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- bountyhunter
Re: Oil pump
16 Apr 2016 01:22When I rebuilt my 750B, it had about 72,000 miles. I assumed the pump would be worn so I ordered a new rotor...... when I checked the wear, there was none. It measured as new. Pros told me that KZ pumps rarely wear unless severely abused or dirty oil run a lot.G-Force wrote: Hi all,I have a 83 kz750 l3.Did a oil pressure test and gauge didn't even move so we thought the gauge was bad and disconnected gauge and turned engine over,no oil came out.The mechanic helping wrenched at kawa in 70s and 80s.He said oil pump / pressure release valve or blockage of oil passage. I removed oil pan the pressure release was not stuck open or closed.The oil pump appears to function OK,did not inspect inside of pump.I held hand over pump screen and with help turned engine over(plug wires off).I could feel some very slight suction.Is there a better way to test pump I know I can check tolerance between pump rotors .How much suction should be felt?oh forgot to mention,this is a fresh top end and the oil light stays on.No problem before rebuild but did find some little rocks in oil pan I'm guessing rocks were around studs,and fell in during disassemble.
If you show no pressure and have the oil light on, that is a worry. If it was OK before the rebuild, maybe some crap like gasket debris or dirt got into a passage?
I might try something like: pull the spark plugs. Fill the engine with light oil (you can thin out some motor oil with mineral spirits) and try to pump it through using the kick starter. You should see oil shooting out the hole the oil pressure sensor screws into.
- Bozo
- Ride it like u stole it
Re: Oil pump
16 Apr 2016 03:00
I had a similar problem but what happened was a cheap gasket kit had a normal o'ring for the oil gallery between the cases and the oil pump> the O'ring that Kawasaki uses is an oval type, therefore I had loss of pressure when hot.
Even a slightly damaged oil pump would still have some pressure and usually they don't just stop working it not pulled apart. I know this might be a bit cheeky but has the gear got the pin in the oil pump shaft that locks the gear??
Does the 750 have a normal or roller bearing on the crankshaft (roller should have a lower pressure than the flat bearing), basically with no pressure you could damage the big end bearings be careful.
- KZB2 650
Re: Oil pump
16 Apr 2016 05:52
When you pull the pan there are 3 tapered oil passage o rings and one large o ring that needs to be in place too
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- G-Force
Re: Oil pump
16 Apr 2016 06:45 - 16 Apr 2016 06:56
Thanks to all,if oil passage block happens would it cause over pressure and activate the pressure release valve and if while doing a pressure test it should not matter if there's blockage because pump is below top end or does pressure test, test oil exiting the top end?I'm hope it's something simple I don't want buy another head and base gasket. No
Last edit: 16 Apr 2016 06:56 by G-Force.
- G-Force
Re: Oil pump
16 Apr 2016 06:59
Not sure morning was off,but I did find one in the oil when I emptied my drain pan.Would missing o ring cause pressure loss?
Re: Oil pump
16 Apr 2016 07:48
Yes.
- Bozo
Re: Oil pump
16 Apr 2016 17:25ditto, yes it would and make sure they are the proper O'ringsswest wrote: Yes.
- G-Force
Re: Oil pump
16 Apr 2016 17:52
Finally home from.after further inspection all o rings were in place but I notice that I installed oil filter wrong. I had the spring under the filter pan.Could that be causing my oil pressure problem.
Re: Oil pump
16 Apr 2016 18:57
It shouldn't.
