Oil pump
  • G-Force
  • G-Force's Avatar Topic Author
Re: Oil pump
21 Apr 2016 09:51
#722203
Still no oil pressure.No oil at pressure test hole.Blew air through the the pressure test hole and could hear air bubbles behind clutch cover so Oil passage way is clear.Oil pump looks new,can't even get feeler gauge between rotors.The three o rings are in place.Seems like pump is doing nothing.I also checked the pins in oil pump,all good.Anybody have some ideas?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil pump
21 Apr 2016 11:19
#722215
Are you missing the O ring in between the case halves?
  • G-Force
Re: Oil pump
21 Apr 2016 13:02
#722227
I didn't split the case.Is it possible for that o ring to come out without splitting the cases and how big is this O ring?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil pump
21 Apr 2016 14:43
#722238
18mm I think. It turns out there is not a pressure relief valve in the pump. The O ring in the case must be missing or deteriorated. There is a bypass valve in the filter housing but that wouldn't cause no pressure unless it's jammed and the filter is loaded up.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil pump
21 Apr 2016 14:50
#722239
Looked at your description and found you have a 750. It has a high pressure system. It has a valve but I don't know where it is. Maybe one of the others can identify where it is. :dry:
