KZ440 LTD Possible Clutch Issue
- BornAgainBiker
14 Apr 2016 10:21
There is a rhythmic chirping/scraping noise while the bike is in gear and moving that seems to be coming from the clutch case area. The noise goes away if I pull the clutch lever in while driving.
There also seems to be a lot of clatter coming from the clutch case area at idle--this also goes away when I pull the clutch lever in.
It looks like I am going have to pull the clutch side engine case and take a look at the clutch basket. I was wondering what I should be looking for that might be causing the noise? :huh:
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- punisher11b
Re: KZ440 LTD Possible Clutch Issue
14 Apr 2016 10:45 - 14 Apr 2016 10:47
Out of curiosity does it make a difference in sound depending on the rpm you are at while moving? The clutch on the 440 I have found to be a pain in the but to get set perfect although that could just be me :silly: . have you double checked the clutch adjustment ? Just so it can be ruled out.
- good luck
Last edit: 14 Apr 2016 10:47 by punisher11b.
- BornAgainBiker
14 Apr 2016 10:59
The clutch adjustment is good, and oddly the sound seems to be related to bike speed rather than engine rpm. :huh:
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- punisher11b
14 Apr 2016 11:11
Hmmm, hope it's not a bearing going out. I might be mistaken but clutch basket issues are usually affected by RPMs . probably need to inspect to verify what the problem is.
- good luck
- JR
14 Apr 2016 11:18 - 14 Apr 2016 12:44
Disregard
Last edit: 14 Apr 2016 12:44 by JR.
- BornAgainBiker
14 Apr 2016 13:55JR wrote: Disregard
JR do you mean just ignore it? Sounds good to me, but I just have to ask--what's the reasoning?
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
14 Apr 2016 14:04
If chain drive, would inspect chain for proper slack adjustment and assure it's properly lubed, and kink-free.
- BornAgainBiker
14 Apr 2016 14:10
Thanks Patton, but it is a belt drive and everything looks good there.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
- JR
14 Apr 2016 17:13BornAgainBiker wrote:JR wrote: Disregard
ha ha
No dont disregard the noise
Sorry for the confusion BornAgain
I had suggested a tight chain and then edited my post and meant disregard my senior moment :laugh:
- BornAgainBiker
14 Apr 2016 18:12 - 14 Apr 2016 18:13JR wrote:BornAgainBiker wrote:JR wrote: Disregard
ha ha
I knew that sounded too easy.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
Last edit: 14 Apr 2016 18:13 by BornAgainBiker.
14 Apr 2016 18:34
I hate the not knowing. Best to have a look.
- BornAgainBiker
15 Apr 2016 06:07punisher11b wrote: Hmmm, hope it's not a bearing going out. I might be mistaken but clutch basket issues are usually affected by RPMs . probably need to inspect to verify what the problem is.
Good point, considering that the noise is related to bike speed, I think I'll start my search in the output shaft bearing area.
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
