KZ650C oil filter
- wrenchmonkey
KZ650C oil filter
14 Apr 2016 09:37
Hi gents,
Quick question. Is the oil filter for my 1979 kz650-C *really* different from the same kz650-B ?
I have a FRAM CH6012 which says it fits 650-B but when I searched online the FRAM part number CH6013 is listed for the 650-C ...
Dang. Even a simple oil change is going south quick
Re: KZ650C oil filter
14 Apr 2016 10:24
The KZ650-B and C models use the same oil filter, but FRAM makes a really poor filter. I would not use it. K&N-401; Mobil-1 M1MC-172; Purolator, WIX; Hi-FLo; etc. are all better choices. Ed
The following user(s) said Thank You: wrenchmonkey
- wrenchmonkey
14 Apr 2016 11:36
Hey Ed. Thanks man. This filter was only for the rebuild process & testing once the engine is back together. So maybe an hour or so use & then dump & change.
Think this FRAM is good enuff for this?
Funny cuz it looks identical to old slimey filter i pulled out of the KZombie.
- zukdave
14 Apr 2016 16:13
The same filter is used on about 9/10 of the early Kaw four stroke street bike's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- RonKZ650
14 Apr 2016 20:15
Just for info, CH6012 is the correct filter, CH6013 is the larger filter used on Z1, KZ1000s ect. I never used the Fram, but would imagine it would be fine. Maybe not the best available filter, but good enough to use and not worry.
15 Apr 2016 05:43 - 15 Apr 2016 05:44
I agree on Fram filters being adequate. The filters on our KZ's don't have a bypass valve or anything else which could cause problems. Just pleated paper of the proper size.
Last edit: 15 Apr 2016 05:44 by Nessism.
