Engine Rebuild Question
- zukdave
Re: Engine Rebuild Question
14 Apr 2016 20:55 - 14 Apr 2016 21:05
Yes you can take the kick start assy. out and run a non kick start clutch cover
If it's a KZ650/750 cover the oil site glass is in the same place so checking the
oil level is the same.
The KZ650/750 and the ZX750 (GPz) use the same clutch cover gasket
but the cover's do not swap due to clutch lever setup.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 14 Apr 2016 21:05 by zukdave.
- KZB2 650
15 Apr 2016 06:33
Thanks Dave and True Steve but in a jam I figure I could probably bump start it and like I said the levers been off for ever.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
