Engine Rebuild Question
- acw380
13 Apr 2016 15:45
I am currently rebuilding a 1981 KZ750 E2 engine and I think I might be missing a part. The person I bought this bike from had no idea what he was doing and slapped the thing together with all sorts of broken/missing parts so I do not trust how anything was put together when I got it. Upon installing the transmission and shifter drum I noticed a large hole with two threaded holes next to it just behind where the clutch goes. I've looked through all the parts I have and through all the diagrams I could find but I still cannot find a part that goes in this hole. Is this feature left behind from some other engine model that uses that same case or am I just overlooking something obvious?
Attachment IMG_3508.JPG not found
- baldy110
Re: Engine Rebuild Question
13 Apr 2016 16:15
Go to partzilla site and look up your bike on their parts diagram.
- acw380
13 Apr 2016 16:20
That's what I have been using. There is no depiction of the right side of the engine and no call out for any part that might go there.
13 Apr 2016 16:22
I was thinking kick start. Looks like SOMETHING was in there.
The following user(s) said Thank You: acw380
- acw380
13 Apr 2016 16:31
The hole is right behind the transmission so I don't think its a kick start. All the pictures I've seen on google have this hole empty as well.
- acw380
13 Apr 2016 16:58
You were right swest/steve. It was a hole for a kickstart from a 650. They use the same case and the 650 has a kickstart option. Thank for the help everyone. Im kind of curious how it works now since its so far back in the engine, apparently you can convert a 750 to accept a kickstarter.
13 Apr 2016 17:02
The kick start turns the clutch basket in which turns the crank.
- car5car
- Banned
14 Apr 2016 09:24
Is it neutral switch on the picture?
96 Yamaha Royal Star
82 Yamaha Virago 920
- zukdave
14 Apr 2016 16:28
You are not going to find it on a 750 part's break down as they didn't use it.
The case casting's are the same as the 650 that's why the hole and mounting
bolt hole's are there.
Look on a 1980 and earlier 650 break down and you will find the starter part's
and if you use a 650 clutch cover you should be able to add a kick starter to a KZ750 motor
but not a GPz (ZX) motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
14 Apr 2016 18:00
Good to know. I like my kick starter even though I hardly ever use it.
- KZB2 650
14 Apr 2016 18:17
Took the kick starter lever off my 650 in the early 80s and have never used it ..... if I got a 81 650 clutch cover without the hole for the kicker shaft can the kick starter guts be removed...... have often thought about it (and not sure if I'd do it but maybe) for weight removal....just never knew if it could be done.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
14 Apr 2016 18:24
It can be taken out but why? When I needed it I REALLY needed it.
