stator allen bolt snapped off
- blink543
09 Apr 2016 16:28
so I had taken my stator off the cover but when I did one of the 3 stator Allen's snapped off inside. I tried to extract it but the extractor tip broke off inside too. so it's not ever gonna come out. so I just have one question. can I get away with just 2 bolts? I was told no because the electromagnetic field causes vibration and the stator could contact the magnet and something gets destroyed.
Adam james
- car5car
- Banned
Re: stator allen bolt snapped off
09 Apr 2016 17:28
No.
Bring it to engine machine shop.
96 Yamaha Royal Star
82 Yamaha Virago 920
- missionkz
09 Apr 2016 18:04Yes correct but a good one. ! I had a buddy do this and for $30, a good machine shop got it and the broken extractor out with an electric discharge etching plasma gadget.car5car wrote: No.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
09 Apr 2016 19:14
I've gotten them out with a punch and tapping on it till it got loose then used a magnet. I've been able to chase the threads with a tap but was prepared to use a Heli Coil if it didn't work.
- car5car
- Banned
09 Apr 2016 21:15
There are some drill bits which can drill out piece of extractor (carbide drill bits????)
09 Apr 2016 21:24
Destroy the aluminum trying it. :S
- wrenchmonkey
10 Apr 2016 06:39
Didn't another member recently post how they used a Dremel tool with a diamond tip bit (I think they said it was an etching bit or something) and basically the tool vibrated the broken bit out and then the broken stud out.
YMMV but good luck!
I just did that job last night and all 3 stator allen bolts and the ph2 screws holding the wire shield plate were solid and crusty. Luckily with patience and lots of PB oil soaking into them I managed to get all free of the casing.
YMMV but good luck!
- z1kzonly
10 Apr 2016 08:47Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
10 Apr 2016 08:49
+1 Wish my parts were that cheap and available.
