Valve guide removal
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
Valve guide removal
23 Mar 2016 12:10
#716968
Hey guys, found a bent ex valve. I am going to replace the valve guide also while i have it apart. any tricks to getting the old guide out?? I did purchase the guide removal tool.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Valve guide removal
23 Mar 2016 12:30
#716970
They can be tricky. You have to heat the head around them enough so they will almost drop out when you tap on them. Too early, you can take metal with it, then get a oversize one to fit.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Mar 2016 12:49
#716972
make sure to clean all the carbon off the bottom of the guide.
i use an air hammer and always remove them with the head at room temp and install with the head hot(450 degrees for 45 mins)
hopefully you don't need oversize guides.
hth,
The following user(s) said Thank You: PLUMMEN
  • bromz
  • 1981 kz1000 csr
23 Mar 2016 12:58
#716974
I dont have an oven to bake it in. can I use a bottle torch carefully ?
  • zukdave
  • zukdave's Avatar
23 Mar 2016 18:53
#717025
The oven in the kitchen will work just fine if the wife don't sent her off shoppin or something and do it anyways.
Easier to ask for forgiveness then permission some time's :unsure: :unsure:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • 531blackbanshee
  • Vendor
  • Vendor
24 Mar 2016 06:52
#717083
a torch can work but you need some way to check the temp.
otherwise your by guess and by golly.
  • Olajoe
  • Olajoe's Avatar
  • Free at last
24 Mar 2016 08:46
#717102
Since it just one valve I'd bottle torch it. Drive it through, and have the replacement chilled in thefreezer. If you forget this steo use lock tite it'll help glide through. Ream to size. Not sure if the guide has a retainer stop so you get that height before taking out the old one.
  • BohicaBob
  • BohicaBob's Avatar
24 Mar 2016 17:49
#717196
Don't forget, if the wife's at home, use the gas grill outside to heat the head up to help ease the guides in and out. B)
  • PLUMMEN
  • PLUMMEN's Avatar
24 Mar 2016 19:44
#717219
If youre going to the trouble of replacing one guide its not a big deal to do them all at the same time,then do a valve job on it and be done. ;)
