What are common kz1000 cylinder head problems?
- car5car
- Banned
22 Mar 2016 12:25 - 22 Mar 2016 12:28
Maybe racing specific problems?
I repaired a lot of car engines but never did motorcycles.
thanks.
thanks.
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 22 Mar 2016 12:28 by car5car.
Re: What are common kz1000 cylinder head problems?
22 Mar 2016 13:37
I believe some of the early J heads had problems wit loose valve guides, but by far the most common problem is ignorant, lazy owners.
The following user(s) said Thank You: 650ed, PLUMMEN, SWest
- DFIGPZ
22 Mar 2016 13:40
Valve guides
Valve seals
Weak Valve springs.
Valve seals
Weak Valve springs.
1984 750 Turbo
- zed1015
22 Mar 2016 16:09
There are no specific design problems or flaws even in racing conditions.
Only the usual wear and tear service issues and moron inflicted damage.
The following user(s) said Thank You: PLUMMEN, SWest
- PLUMMEN
22 Mar 2016 19:58
It depends on what youre trying to get out of it,build to suit your needs.
- Moriwaki Kawasaki Monster
02 Apr 2016 22:10
"cam cap bolts stripping threads".
These heads have been worked on numerous times by people who are not always experienced.
Bench test all cam cap bolts. Tighten all bolts by hand.
DO NOT use a torque wrench even if it is a Snap On
03 Apr 2016 06:50
Cutting corners and reusing worn out parts.
