Blown gasket or worse
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
11 Mar 2016 13:11
#714949
Well riding at bike week on the freeway, I suddenly lost power like I was out of gas. Smoke was coming out of the center carbs and also a lot of oil upfront. do copper gaskets blow their seal? Oil is at normal level too. When I crank the kickstart I don't hear or feel it grind. Hopefully not a bent valve/destroyed piston.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Blown gasket or worse
11 Mar 2016 13:18
#714952
Do you hear a chirping sound?
  • TexasKZ
  • TexasKZ's Avatar
11 Mar 2016 16:34
#714980
I can't imagine which gasket could make all of those symptoms. I hope for your sake I'm too ignorant, but that souns like a more expensive problem.
It seems to me that the only way to push smoke out of the carbs is for the intake valves to be open at the wrong time, or for the ports to be cracked in a way that cylinder pressure is entering the ports.
I hope somebody has a simpler, cheaper explanation.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Mar 2016 16:47
#714983
A bent valve or valves can do it. Only thing to do is open it up.
  • ayeckley
  • ayeckley's Avatar
11 Mar 2016 22:50
#715051
swest wrote: A bent valve or valves can do it. Only thing to do is open it up.
Compression test first, eh?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • PLUMMEN
  • PLUMMEN's Avatar
12 Mar 2016 06:19
#715067
Do a leak down test on it. ;)
  • DobbinsCMA
12 Mar 2016 10:50
#715103
Yah. I don't have a leak down tester. It's on my list with blasting cabinets. Thanks for the replies guys. Pictures this week
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • TexasKZ
  • TexasKZ's Avatar
12 Mar 2016 16:09
#715141
You might be able to rent or borrow one from an auto parts store.
