440 ltd bobber
- steamboat927
- Thank you received: 2098
steamboat927 wrote: so im new and wanted to do some basic things to my 440 ltd mainly the first is to cut the trumpets off. how is the sound without the trumpets?
Foolish Mortal! :woohoo: :lol: :lol: :lol:
how is the sound without the trumpets? Imo, loud, cheap and obnoxious. :pinch:
And probably hate yourself in the morning.
Likely to lose a significant degree of low end torque and pull-away strength.
Carb tuning a non-stock KZ440 can be problematic.
Sorry about the discouragement and negativity.
Perhaps others may offer a more positive opinion
- Thank you received: 1656
What's the condition of the motorcycle & does it run?
- steamboat927
The bike needs a good, fully charged battery to run right as it provides the energy to fire the ignition coils.
make sure the spark plugs & spark plug wires are good w good connections. I would service the timing advancer.
also, the bike has cv carbs, so it's important that the airbox & air filter are good and properly installed. on some 440s supposedly the airbox cap can be installed incorrectly --- a loose cap will lead to a vacuum leak & poor running.
- punisher11b
- Thank you received: 22
Side note: if you get tired of dicking with those notoriously finicky carbs, there are easier options. I hate messing with them myself. Just my 2 cents
- good luck
- 77Davo650
- Thank you received: 4
I am using the stock carbs, although with the pods and higher flow exhaust I did have to experiment with the jetting for a while but it runs great now. I'd agree though, make sure the engine is in top shape before changing things up.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
- loudhvx
- Thank you received: 1616
If it's like the 400, there may be a chance you can cut it partially and make it somewhere in between. The 400 mufflers were made of several chambers connected by offset pipes. We carefully measured the distance, using a stick inserted into the muffler, from the end of the muffler to the inside chamber wall and cut near the chamber wall. There are a few chambers and we ended up cutting off the end and the last full chamber. The result was louder, but not obnoxious. It doesn't look great, but my buddy was broke, and this cost nothing. The muffler was banged up and rusty so it wasn't a big deal. I wouldn't cut a pristine stock exhaust. They are becoming scarce. (This was a factory 2-into-1 by the way.)
Looking back now, I think the 440 megaphone mufflers could be pretty different from the 400 zeppelin muffler.
I'll see if I can dig up a photo.
You can see the offset transfer pipe becomes the new exit of the muffler.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Thank you received: 2749
- steamboat927
- steamboat927
- loudhvx
1981 KZ550 D1 gpz.
Other links.
