Simple 750 motor mount question
  • tri650
  • tri650's Avatar Topic Author
01 Mar 2016 15:15
#713283
I have a 1982 Gpz 750 and having an issue with the front engine mounting nuts not running flush with the mounting hole once you push the bolt through. The engine casing seems to have a lip where the mounting hole would meet the nut, meaning the nut is not flush with the mounting hole. There is about a 1/2" gap that exists because of the lip. I thought maybe the lip was there to keep the nut in place, but I can't slip the nut into that space. It is this way on both sides. See pic below. Any thoughts?
Attachment Mountinghole.png not found
Attachment Engienmount-2.png not found
  • Nessism
  • Nessism's Avatar
Re: Simple 750 motor mount question
01 Mar 2016 15:40
#713288
The proper sized nut has a 14mm hex. The nut you are using looks like a 17mm hex. You gotta find the proper nut.
01 Mar 2016 15:53 - 01 Mar 2016 15:57
#713289
To me it looks like you're doing it backwards. On my bike the nut is outboard; the bolt head fits in the engine slot. Ed
Attachment 00003c-2-3.jpg not found
Last edit: 01 Mar 2016 15:57 by 650ed.
  • Nessism
  • Nessism's Avatar
01 Mar 2016 16:04 - 01 Mar 2016 16:04
#713295
650ed wrote: To me it looks like you're doing it backwards. On my bike the nut is outboard; the bolt head fits in the engine slot. Ed
The bikes with the rubber mounted engine mounts (like this GPz) use a different mounting arrangement than your 650.
BTW, pretty sure I've got the mounting hardware you need tri650. PM me if you get stuck and can't find the nut.
Last edit: 01 Mar 2016 16:04 by Nessism.
  • tri650
01 Mar 2016 17:13
#713317
Thanks for the replies and I appreciate the offer of the nuts. If you have them can you measure across? I just want to make sure of the size across. I thought I had the right nuts but they must have a smaller outside diameter. If I can't find the right ones I will send you a PM.
  • tri650
01 Mar 2016 17:23
#713321
Here is nut I thought was correct:
Attachment IMG_1331.jpg not found
  • Nessism
  • Nessism's Avatar
01 Mar 2016 17:48
#713332
The engine case is shaped in such a way to hold the nut tight. You have to have the nut oriented in just the right way or it won't fit into the notches in the case.
  • tri650
01 Mar 2016 18:05
#713336
Is this the correct nut?
  • Nessism
  • Nessism's Avatar
01 Mar 2016 18:06
#713338
tri650 wrote: Is this the correct nut?
Does it fit into the notches in the case?
  • tri650
01 Mar 2016 18:10
#713340
No - but can't imagine what will fit in that space. I am going back out to the garage to see if I am missing something.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Mar 2016 18:12
#713341
Will the bolt head fit?
  • Nessism
  • Nessism's Avatar
01 Mar 2016 18:20
#713344
swest wrote: Will the bolt head fit?
Good question. Try flipping the screw around the other way.
