2000 KZ1000 ENGINE FAILURE
  • MDZ1rider
  • MDZ1rider's Avatar
Re: 2000 KZ1000 ENGINE FAILURE
04 Mar 2016 13:30
#713819
Sounds to me more like poor fuel flow, Could be petcock, fuel filter or collapsed/pinched fuel line. The float bowls trickle fill and the bike starts fine. However, they are being emptied faster than the flow can refill them. The bike will start running poor as the first bowl falls low and eventually quit as the other 3 run dry.. Let it sit for a few minutes and the bowls slowly refill to repeat the cycle.
Have a catch can ready and pull the fuel line from the "T" between carbs 2&3. Verify you have a good steady flow. You could also check if the bike runs longer at idle vs.higher RPM's before it dies. Lower RPM's will use fuel at a slower rate and therefore should take longer for the symptoms to appear.
  • strum
  • strum's Avatar
04 Mar 2016 15:46 - 04 Mar 2016 15:48
#713849
Cool find you have there. Really if its been sitting all these years then the carbs need to come off and be cleaned.
you may get by with doing what bountyhunter said but why mess around? pull those carbs apart and clean them well replace any o-rings that need it and make sure your float needles are clean ,seat well and float height is correct .
Then when you get your valves adjusted youll have a good running machine.
Clean your fuel tank out also and inspect for rust. get a new filter. verify the petcock is flowing .
good luck
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Last edit: 04 Mar 2016 15:48 by strum.
  • redhawk4
  • redhawk4's Avatar
04 Mar 2016 16:54
#713857
strum wrote: Cool find you have there. Really if its been sitting all these years then the carbs need to come off and be cleaned.
good luck
I agree with Strum on cleaning the carbs and fuel system properly, while 550 miles shouldn't have worn anything out, the fact that it had fuel in it at some stage and then sat is enough to have things well gummed up in that respect.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • trianglelaguna
  • trianglelaguna's Avatar
04 Mar 2016 17:23
#713862
It runs fine when cold, but after 5 to 10 minutes the engine loses power to the point that it won’t idle. If you leave it alone just for a few minutes, it will start again just fine, until it warms up,
Iread the whole post -replies etc
then went back and re-read the problem as you describe
thoughts I have---
NOT i the engine-NOT valves
same as you and others have said its a fuel or coil ---or??? ignition that expands and shorts
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
04 Mar 2016 17:24
#713864
by the way welcome and EXCELLENT bike and score for you!!!
once you sort this out your going to have great time--good deal---how much did you pay for it u.s??
1976 KZ900
2003 ZX12R
2007 FZ1000
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
04 Mar 2016 17:49
#713870
swest wrote: Welcome. Sounds like tight misadjusted valves.
^^^+1
What Steve says!!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • ed spangler
  • Tennessee Z
04 Mar 2016 17:55
#713871
good luck
Forgive me but something just occurred to me...you are in Brazil??, in Brazil isnt it common to run E-85?? or even E100?I wonder.....Alcohol in the fuel??
Brazil used to be really big on running mostly Alcohol...Right?
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
04 Mar 2016 18:34
#713872
Did you check the oil level or change it? If it's old it turns waxy.
Any smell of gas in the oil?
  • RAFA73
  • RAFA73's Avatar Topic Author
05 Mar 2016 01:20
#713899
Hello Everyone,
I am impressed with the amount of replies my post has received. I feel very lucky that this forum exists and that I have found it. Many thanks for all your good advice, I really appreciate it.
Most of you are saying my bike needs carb cleaning or valve adjustment. Some of you say it could also be a bad coil. Since the early replies focused more on valve adjustment, that's where I started. I found 2 valves that needed adjustment and I'm waiting for the tool to arrive by the mail to swap shims. Once that is solved I'll run the engine to see what happens, and if nothing changes, I'll work on the carbs. Since the carb kit is not expensive, I think I'll order one in advance, just in case. If all that doesn't work, I'll move to the coils.
You asked me a few specific questions, here are the replies:
- I have never cleaned the carbs and I don't know if it was ever done. I'm not an experienced motorcycle mechanic, and I don't have easy access to spare parts, so I don't want to fool around with the carbs unless I have to.
- It's not the fuel tank, filter or petcock. I have ran the engine without them and the problem remained. The hoses were inspected too.
- When failing, the engine runs better at high RPMs than at idle. The first symptom is having no idle, the lack of power takes a few minutes more.
- The bike is worth about US$5K to US$8K in Brazil. I know it sounds too much, but that's the way things are here, government is a thief and duties are very expensive.
- Yes, pure ethanol is widely used in Brazil as a fuel and our gas can have up to 25% ethanol mixed in it. But that is not the issue, I have several other bikes, from a 1975 Yamaha GT80 to a 2007 HD Road King and they run just fine with our gas.
- The engine oil is clean and at level. I haven't smelled it but I guess it's too late now. My plan is to change the oil as soon as the problem is solved.
Thank you all and have a great weekend!
Rafael.
2000 Kawasaki KZ1000 Police
1974 Suzuki GT750
1976 Suzuki GT750
1975 Suzuki RV90
1976 Suzuki RV90
1975 Suzuki RV125
1976 Suzuki RE5
1975 Yamaha GT80
1974 Yamaha RD350
1972 Honda ST 70
1975 Honda GL1000
1979 Honda CBX 1050
1980 Honda ATC 110
2007 Harley Davidson Road King Police
  • RAFA73
05 Mar 2016 01:31 - 05 Mar 2016 01:31
#713900
By the way, when I look online all I find is carb kits for early KZ1000s, from the 1970s and 80s, but not for later ones, such as my 2000. Will earlier kits fit my bike?
1974 Suzuki GT750
1976 Suzuki GT750
1975 Suzuki RV90
1976 Suzuki RV90
1975 Suzuki RV125
1976 Suzuki RE5
1975 Yamaha GT80
1974 Yamaha RD350
1972 Honda ST 70
1975 Honda GL1000
1979 Honda CBX 1050
1980 Honda ATC 110
Last edit: 05 Mar 2016 01:31 by RAFA73.
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Mar 2016 05:36
#713910
Chances are you don't need a kit, just a cleaning. Something to look at.
The following user(s) said Thank You: RAFA73
  • DobbinsCMA
  • DobbinsCMA's Avatar
05 Mar 2016 09:58
#713949
Wow awesome bike! Where is this crated bike your speak of? Id love to come get it! I have some friends that live in brazil so it would so fun to ride through your beautiful country.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
