Am I At Top Dead Center
  • kzharpe
  • kzharpe's Avatar Topic Author
01 Mar 2016 00:22
#713160
I had to set my bike back to top dead center tonight (77 kz650) and I am not 100% sure I can call the night a success. I lined the 1/4 cylinder mark up on the crankshaft, lined my arrows up at the top, and counted the links. My factory manual says there should be 36 links. Well I was one link off. I bumped it down a link and got what I was looking for. Only problem is that one arrow is buried and the other one is perfectly level now that i have that 36 link gap. At 35 links they were perfect and now it just doesnt seem right. ill post some pictures so you get the idea
Here is where i lined up the camshaft
Attachment 20160301_004743.jpg not found
This side is level
Attachment 20160301_004750.jpg not found
This side is buried
Attachment 20160301_004759.jpg not found
When I split the difference and even them out this is what it looks like on the bottom, its pretty much lined up with the F mark
Attachment 20160301_004858.jpg not found
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Am I At Top Dead Center
01 Mar 2016 06:59
#713194
On my Z1 the exhaust arrow is just slightly below the case. One tooth back it will be too far. The number of pins is the important thing. I don't know about yours but on mine I count starting with the next pit up.
  • kzharpe
01 Mar 2016 07:01
#713195
Yeah I'm sitting at 36 pins and that's following this
Attachment Screenshot_2016-02-22-01-21-54-2.png not found
1977 KZ650
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Mar 2016 07:03
#713196
You're good to go then.
  • kzharpe
01 Mar 2016 10:13
#713236
Awesome at least thats going right. Now to order some more shims and removed the bolt that snapped when I removed my carb holders. Not looking forward to that at all
1977 KZ650
01 Mar 2016 10:25 - 01 Mar 2016 10:26
#713239
You need to soak stubborn bolts and other fasteners with Kroil for a couple days before trying to remove them. You will be surprised at how well it breaks the bond and makes them easier to remove; this stuff really does work! It's a million times better than dealing with broken or stripped fasteners. For Kroil see www.kanolabs.com/google Ed
Attachment Kroil-2-3.jpg not found
Last edit: 01 Mar 2016 10:26 by 650ed.
  • kzharpe
04 Mar 2016 12:01
#713807
I will absolutely be getting some of that penetrating oil. This was an absolute nightmare trying to fix. Some good did come of it though
www.kzrider.com/forum/2-engine/601465-ti...-or-easy-outs#713806
1977 KZ650
