Cylinder 1 or 2 misfire
28 Feb 2016 19:39 #712999 by Willy1803
Cylinder 1 or 2 misfire was created by Willy1803
How would I figure out which cylinder is misfiring an how would I fix it
  • SWest
  • 10 22 2014
28 Feb 2016 19:43 #713000 by SWest
28 Feb 2016 19:50 #713002 by Willy1803
Replied by Willy1803 on topic Cylinder 1 or 2 misfire
Ok you think that might also fix my high rpm trubble an what am I looking for on the plug an then what do I do
  • SWest
  • 10 22 2014
28 Feb 2016 19:55 #713003 by SWest
Replied by SWest on topic Cylinder 1 or 2 misfire
Pics of the plugs and tell us what you've done with the bike.
28 Feb 2016 21:04 #713009 by Willy1803
I've rebuilt carbs then been clean and I changed the sprockets I'll get pics after school tomorrow
29 Feb 2016 05:13 - 29 Feb 2016 06:09 #713015 by martin_csr
Replied by martin_csr on topic Cylinder 1 or 2 misfire
How do you know the misfire is with #1 or #2?
Engine cold >>> after starting the engine, pat the exhaust pipes to see if they're warming up evenly.
After the engine is warmed up, use a spray bottle to mist the pipes --- the water should sizzle.
Don't get burned --- don't touch the pipes when they're hot or starting to get hot.
Battery. what's the condition of the battery? the bike needs a good, fully charged battery to run right as it provides the energy to fire the coils. I use a Ctek US 0.8 smart charger & VC97 digital multimeter.
Ignition system. Any idea if your bike has the original ignition coils? The stock coils can be problematic, especially since the spark plug wires are molded into them. If the coils are old, they may need replacing. but maybe not. and new spark plug wires. Check, clean & lubricate the timing advancer. be sure to separate the rotor from the body so that it can be properly serviced.
Last edit: 29 Feb 2016 06:09 by martin_csr.
29 Feb 2016 05:48 #713022 by TexasKZ
Replied by TexasKZ on topic Cylinder 1 or 2 misfire
Was it missing before the carbs were cleaned?
29 Feb 2016 13:01 #713090 by Willy1803
Heres the pic soark plug
29 Feb 2016 13:01 #713091 by Willy1803
Yes it was
29 Feb 2016 13:08 #713092 by Willy1803
How would i cheek the ignition system
  • SWest
  • 10 22 2014
29 Feb 2016 13:32 #713098 by SWest
29 Feb 2016 13:42 #713099 by Willy1803
No
