'81 GPz clutch is apart, take a look.
Re: '81 GPz clutch is apart, take a look.
27 Feb 2016 15:44
Handle it biker. :woohoo: :lol:
- MadShad
27 Feb 2016 19:56
New springs are in, old disks are back in, oil is back in the bike.
the actuator has been cleaned, lubed and readjusted. I might be the only person to see the inside of that actuator in 35 years, I think the grease was about 3 weeks away from becoming diamonds..
pushrod was straight and the cable was completely removed from the bike and flushed with wd40 and then lubed with lithium grease forced into the cable using a plastic bag taped on the end.
I can't comment on how the clutch grabs yet but the action is smooth and I didn't notice much of an increase in lever effort.
Now I just need that decent weather that the forecast has promised tomorrow and I'll know for sure
The ebc springs were taller but had a smaller material size or wire diameter .
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
- KZB2 650
28 Feb 2016 06:55 - 28 Feb 2016 06:58
Wow EBC's are defently taller and have never thought the lever was much harder to pull ...... I've used Barnett's springs for ever and my old ones were sagged .040 over the new .... threw the stock plates and springs away in 84 when I replaced em with Barnett plates too....... what a mistake and waist that was bet the stocker's were just broken in..... went back to oem plates this time..... Will probably replace the springs every 5-7 years. Betting you fixed it... am pulling for ya.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 28 Feb 2016 06:58 by KZB2 650.
28 Feb 2016 07:02
My springs were 40 years old. They don't get heavy use like valve springs. These used 900 springs are like new and the plates perfect. Never has a clutch slip.
- KZB2 650
28 Feb 2016 07:20
Thinkin you'd be surprised if you ever checked their tention and length..... my cam tensioner spring was quite a bit shorter and weaker along with the the oil filter spring too..... true valve springs have a much harder life but heat and use over 40 years has to work on them.
1978 KZ650 b-2
- MadShad
28 Feb 2016 07:24
Well, my problems are over at least for the time being.
Just took it out, no slip on upshifts and it pulls harder at the top end so although i didn't notice it must have been slipping there as well.
Now i get to enjoy this warm day, untill something else goes wrong....
Thanks again!
Thanks again!
28 Feb 2016 07:32
Good for you. Think positive. It's a beautiful day.
NOW RIDE THE PISS OUT OF IT. :woohoo:
28 Feb 2016 14:41
Those EBC springs have almost a full coil less than the stockers, which means they will be a good bit stiffer.
Some guys use three HD aftermarket springs mixed with three stockers. That way you don't have as much hand effort as a full set of aftermarket springs.
- undiablo
28 Feb 2016 14:46
Good to hear problem is solved. Ride it like you stole it!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- loudhvx
28 Feb 2016 15:56
These only have 5 springs, so it would not be recommended to mix springs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
