'81 GPz 550 clutch slipping.
  • MadShad
  • MadShad's Avatar Topic Author
Re: '81 GPz 550 clutch slipping.
23 Feb 2016 19:49
#712227
And from a manual I downloaded, again in the 1981 supplement, also indicating clockwise.
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
23 Feb 2016 19:51
#712228
OK. If you are turning it CLOCKWISE until it is hard to turn CLOCKWISE is turning it IN (tighter). If you then turn it COUNTERCLOCKWISE you are turning it OUT (looser).
Earlier in this thread you stated "I've adjusted it by loosening the lock nut on the clutch adjustment, backing off the adjusting screw until I feel resistance and then screwing it back in 1/4 turn." That is the opposite of what either manual says to do because you do not "back off" the adjusting screw until you feel resistance. Backing off the adjuster makes it looser not tighter. and screwing it IN makes it tighter, so you do not screw it IN further once resistance is felt; you screw it OUT. Ed
  • RonKZ650
  • RonKZ650's Avatar
23 Feb 2016 19:54
#712230
Whatever the cause is, adjustments are irrelevant if you have the correct free play at the lever. Yes, I suppose adjusting using the adjuster on the engine, turning til it seats, back off 1.2 turns, whatever is probably optimal if you can believe the manual, and there are major inconsistencies in procedures published. Really, adjusting the cable free play by the inline adjusters do 95% the same thing as the engine adjuster. Get freeplay correct in the lever, if the clutch slips, adjustments are going to be fruitless. In 300,000 miles of KZ riding, I've never found need to adjust at the engine, but I've never had any clutch problem to feel the need to.
  • MadShad
23 Feb 2016 20:13
#712232
650ed wrote: OK. If you are turning it CLOCKWISE until it is hard to turn CLOCKWISE is turning it IN (tighter). If you then turn it COUNTERCLOCKWISE you are turning it OUT (looser).
"Back off" = counterclockwise
"Screw it back in" = clockwise
I said I "backed it off" until i felt resistance.
Per the manual " counterclockwise until it becomes hard to turn"
Then I "screw it back in" 1/4 turn
Per the manual "turn clockwise 1/4 turn"
So you screw it IN or CLOCKWISE then set the locknut, I understand this is opposite of mist bikes.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Feb 2016 20:30
#712235
Reverse threads.
  • loudhvx
  • loudhvx's Avatar
23 Feb 2016 20:47 - 23 Feb 2016 20:49
#712238
It does not have reverse threads. See diagram I posted.
The terms "in" or "out" really have no meaning since the screw does not move. It's shoulder stays against the cover surface. The only meaningful terms are CW and CCW.
The adjustment is more critical for the newer style actuator. The upside is that the design makes for an easier clutch to hold in. Once the balls roll out of their pockets, they do most of the holding for you. A sluggish cable will be a problem, though.
Last edit: 23 Feb 2016 20:49 by loudhvx.
23 Feb 2016 20:50 - 23 Feb 2016 20:53
#712239
Correct. Reverse (left handed) threads.
So regardless of left handed / right handed; clockwise or counter clockwise; you still turn the adjusting screw IN - NOT OUT until you feel resistance; then you turn it OUT to give it some slack. You DO NOT "Back off" the adjusting screw until you feel resistance or "Screw it back in" after resistance is felt, because that is the opposite of what needs to be done. Backing off the adjusting screw implies making it looser as in screwing it OUT, and screwing it IN implies making it tighter. Maybe the OP doesn't fully understand that with left handed threads turning the adjuster screw counter clockwise is screwing it IN and turning it clockwise is screwing it OUT? Hopefully, anyone else reading this thread when looking for advice on adjusting the clutch will understand. Ed
Last edit: 23 Feb 2016 20:53 by 650ed.
  • loudhvx
  • loudhvx's Avatar
23 Feb 2016 20:54 - 23 Feb 2016 20:58
#712241
650ed wrote: Correct. Reverse (left handed) threads.
So regardless of left handed / right handed; clockwise or counter clockwise; you still turn the adjusting screw IN - NOT OUT until you feel resistance; then you turn it OUT to give it some slack. You DO NOT "Back off" the adjusting screw until you feel resistance or "Screw it back in" after resistance is felt. Backing off the adjusting screw implies making it looser as in screwing it OUT, and screwing it IN implies making it tighter. Maybe the OP doesn't fully understand that with left handed threads turning the adjuster screw counter clockwise is screwing it IN and turning it clockwise is screwing it OUT? Ed
Maybe you didn't see my post. The threads are standard right handed. The screw does not move in or out, so the terms mean nothing. Only CW and CCW have meaning here.
Please see the diagram I posted, or it won't make any sense.
The OP seems to understand it fine.
Last edit: 23 Feb 2016 20:58 by loudhvx.
  • MadShad
23 Feb 2016 20:56
#712242
loudhvx wrote: Yes, oil level. In my experience, the time when a clutch begins to slip is right after an oil change. Even the manual states a high oil level will cause slippage, so check that first.
Also, in all of the 550 bikes I've owned or worked on, I have yet to find a clutch disk that measures below the service limit. I've also bought aftermarket disks that came thinner than old factory disks. So you likely won't need disks.
Steel plate warpage is not very common unless it's been run while slipping for many miles.
The springs do tend to lose some pressure over time. That is usually the only wear I can find.
Once you have the clutch apart you can do what I think is the single most effective thing I've done to the clutch:
If you notice, on the steel plates, one side is sharp and the other is rounded. If you stack them so all of the sharp edges face one way, the clutch tends to grab harder, but also has a harder time releasing. If you stack them the other way, the clutch releases nicely, but slips a bit more. I found an old set of plates and just very lightly rounded the sharp edges (interior teeth) with a wire wheel. That set worked best of all. It grabbed nicely and released just as nicely. It makes sense since the plates' teeth can move easier on the hub splines. I also did the other things you would consider, such as taking super fine grit and polishing the wear marks on the basket fingers and hub splines. This did help a little as well.
After going to pods and rejetting, I was still getting some major slippage. I ended up putting small shims under the springs. The heavier duty springs were just way too stiff for city driving.
After you check the oil level, you may want to double the check the clutch adjustment since it's easy to do. The manuals are vague/wrong for the newer type actuator.
Here's a link to some details on the clutch adjuster, in case you haven't already seen it:
gpzweb.s3-website-us-east-1.amazonaws.com/ClutchReleaseMech.GIF
I'll add it as an image, but you might need to download it to read it.
  • loudhvx
  • loudhvx's Avatar
23 Feb 2016 21:03
#712244
Thank you. :laugh:
  • undiablo
  • undiablo's Avatar
24 Feb 2016 05:02
#712263
Ed:
I believe Loudhvx is right 100%.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
24 Feb 2016 06:24
#712275
undiablo wrote: Ed:
You, Loudhvx, and the original poster are all correct; I was wrong. I was looking at the Kawasaki Service Manual but not at the 1981 supplement within that manual, and the 1981 clutch adjustment is different than the earlier adjustment. PLEASE accept my apology. :blush: Ed
