At what point does the trans need to be built?
- rustedcutlery
18 Feb 2016 11:51 - 18 Feb 2016 12:25
Doing a 1170 with .435 cams, gpz head, rs36 flatslides, at what point is it necessary to do a billet shift fork, hd second gear? The bike's life will be 99% street use, maybe 1 weekend a year at the strip, I don't plan on a slick or anything, but I don't want to have to split the cases to replace something that I could do now while it's apart.
Last edit: 18 Feb 2016 12:25 by rustedcutlery.
Re: At what point does the trans need to be built?
18 Feb 2016 14:13
Then do it now.
- missionkz
18 Feb 2016 14:21I think you answered your own question... no time like the present if the engine is out of the frame and down.rustedcutlery wrote: Doing a 1170 with .435 cams, gpz head, rs36 flatslides, at what point is it necessary to do a billet shift fork, hd second gear? The bike's life will be 99% street use, maybe 1 weekend a year at the strip, I don't plan on a slick or anything, but I don't want to have to split the cases to replace something that I could do now while it's apart.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- DFIGPZ
18 Feb 2016 14:36
What trans are you working with ? KZ "J" 83/84 GPZ ?
1984 750 Turbo
- etbike3135
18 Feb 2016 15:32 - 18 Feb 2016 15:34
No matter what bike you are working on I would keep in mind that once the bike is riden the first time the trans is wearing. So if you want a good trans and don't want to split the cases in a year or two then do it now. A basic undercut is all you would need. Leave all the billet and heavy-duty stuff to the slick and wheelie bar guys.
80% of transmissions in motors I take apart are not good enough to be reused for street riding
1973 Kawasaki Z1
18 years in dragbikes
Last edit: 18 Feb 2016 15:34 by etbike3135.
- PLUMMEN
18 Feb 2016 18:42
Check for worn parts while its apart,fix what needs fixing. Save the billet stuff for the guys running a slick or really sticky 180 tires.
- rustedcutlery
18 Feb 2016 19:11 - 18 Feb 2016 19:17
Well I think I'm going to order a undercut trans from pit stop. Ape charges more for just the machine work. I'm going to do the new bearings while I'm at it. Maybe someday I'll slap a sticky tire on for a weekend at the track, but as of now, I don't plan on it.
www.pitstopperformance.com/kawasaki-z1-k...ed-transmission-p-72
aperaceparts.com/transmissions.html
Last edit: 18 Feb 2016 19:17 by rustedcutlery.
- Kapahulu
18 Feb 2016 21:47 - 18 Feb 2016 21:48
With all the other work you're doing, might as well spend another $300-$400 and get this done. I used to have a KZ900 with undercut trans. That bike shifted better than any other KZ I have owned.
Just put together an H2 motor. Measured the clearance between gears, carefully selected a shift drum and shift forks. Fifty miles later the trans jammed up. H2's and H1's are known for having fragile transmissions. Not wanting to split the cases again because of the trans, this time I sent it to Fast by Gast for undercutting and shimming.
2strokeworld.com
2strokeworld.com
Last edit: 18 Feb 2016 21:48 by Kapahulu. Reason: typo
- bluej58
19 Feb 2016 15:47 - 19 Feb 2016 15:47
Don't forget all the O-rings I think there is around a dozen.
If your case is from 78 or before I have a list somewhere.
JD
JD
78 KZ1000 A2A
Last edit: 19 Feb 2016 15:47 by bluej58.
- zukdave
19 Feb 2016 16:12
I'd do the APE over shift bushing while your in it
your shift fork's will like you for it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- darlington
- S. Darlington
26 Feb 2016 07:40
I thought the 83-84 GPZ 1100 trani was already undercut from factory! I run a 1984 KZ 1100R motor in basically stock in my road race 1000J and love the motor. The trani shifts great and the clutch is surprisingly easy to actuate and doesnt slip at all. I'm running 31CR's and a 82 GPZ 11 exhaust cam for better pull out of the corners.
I looked at an 84 trani a few weeks ago and you can see the dogs are undercut from factory. Not sure about the ratios, if they are different from an 82 GPZ/J
Keeping the good times rolling since 1982. Helping people with parts ,technical support and service of the 70's 80's Kawasakis in Eastern Ontario. Building roadrace bikes for individuals involved in Vintage Road Racing in the eastern Ontario region.
- rustedcutlery
09 Mar 2016 12:58bluej58 wrote: Don't forget all the O-rings I think there is around a dozen.
JD
If you have this list, I could really use it.
