Check out my plugs, what do you think?
- kzharpe
11 Feb 2016 13:26 - 11 Feb 2016 13:33
Ok guys, I was having issues with my bike running lean but I was running a straight pipe. Now I am still running a straight pipe but I switched to a 4 to 1 header. I pulled my plugs after running a few miles and this is what they look like. Keep in mind they are brand new plugs but I think I'm running decent now. Maybe a little lean though
Attachment 20160211_172504-3.jpg not found
Attachment 20160211_172519.jpg not found
1977 KZ650
Last edit: 11 Feb 2016 13:33 by kzharpe. Reason: Forgot Pictures
Re: Check out my plugs, what do you think?
11 Feb 2016 14:58
You're looking for peanut butter color. One step up on the pilots?
- bountyhunter
11 Feb 2016 15:20
Definitely too lean. Do you have a canister to hang on the straight pipe?
- kzharpe
11 Feb 2016 15:55
Yes I have a can to put on but I'm having trouble getting it clamped on there tight enough. Stupid thing fell off cruising down the road. Tried to tighten it again and snapped the bolt on the exhaust clamp. Can't figure out how to keep the thing on good enough
1977 KZ650
- loudhvx
11 Feb 2016 16:15 - 11 Feb 2016 16:17
All my bikes had a tan color on the plugs a few years ago, but now they are always a grey color... About the same shade in intensity, but in grey instead of tan. I suspect fuel has changed.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 11 Feb 2016 16:17 by loudhvx.
- kzharpe
11 Feb 2016 16:21loudhvx wrote: All my bikes had a tan color on the plugs a few years ago, but now they are always a grey color... About the same shade in intensity, but in grey instead of tan. I suspect fuel has changed.
So I might be alright?
1977 KZ650
- loudhvx
11 Feb 2016 16:27 - 11 Feb 2016 16:29
My phone wont give me a good look at your photos. If your jetting is close to correct, the plugs take a lot more time to show a representative picture. So they might get darker with time.
If the ring on the plug body is dark, you might be ok. The tip and ground electrode should mot be as dark as the ring.
To me they look white, rather than grey, so prob lean as others said.
I was just saying grey might be normal instead of tan.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 11 Feb 2016 16:29 by loudhvx.
11 Feb 2016 16:39
I try to put 100 miles on the bike before I change anything. When jetting it can seem rich but after being ridden it could lean out as things change in the engine.
- jdvorchak
15 Feb 2016 05:52 - 15 Feb 2016 05:53
I can't tell from the first pic because it could be angle or lighting. If there is a white crusty stuff on the electrodes then way too lean. The second pic looks about right.or maybe a tad on the lean side.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
Last edit: 15 Feb 2016 05:53 by jdvorchak.
- GregZ
15 Feb 2016 06:37
Looks a little lean
Best way to check plugs, take that bike wind it up to red line in third gear , use thumb and hit the kill switch to off. pull over, pull a plug and look see , that will give you your best reading
