- Thank you received: 2
Where the hell is the mark
- shamal
1983 kz 550 h
- Bozo
- Ride it like u stole it
- Thank you received: 105
shamal wrote: On this rotor , i thought it can be 180° off. I cant find any mark on the lobe
The part you are showing is keyed when it goes on the crankshaft - it cannot be 180 degrees out, you should see the T 1-4 mark point to the marker on the timing cover which is screwed to the engine when piston one / four are in the top position.
I suspect you haven't fitted the cover with the timing mark. Let me know if you have a problem understanding this, I can take a photo if required.
- shamal
- shamal
- rrsmsw9999
- Thank you received: 67
Attachment IMG_1459.jpg not found
There should be a "TEC" and number "1016"mark on it. The cam lob should point that way.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Bozo
shamal wrote: Im referring about this
My bad, my suggestion is to find out which pickup is triggered (by the cam on the part in picture) i.e when on F 1-4 the correct pickup for that coil to plugs 1-4 should be triggered (the cam should point to the correct pickup).
Sorry this is hard to describe.
- Thank you received: 2823
- shamal
1983 kz 550 h
- Thank you received: 2234
- Thank you received: 2098
Nessism wrote: . . . with the 1-4 T mark pointing up, the rotor points to the left.
That's correct.
When the pointed end of the rotor passes by the left-hand (9 o'clock) pickup module, a signal is sent to the ignition coil that fires outside cylinders 1 and 4.
When the pointed end of the rotor passes by the right-hand (3 o'clock) pickup module, a signal is sent to the ignition coil that fires inside cylinders 2 and 3.
- rrsmsw9999
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- z1kzonly
- Thank you received: 540
Seeing your working on it, TRY it both ways. process of elimination. And No it won't fire 180 off.
