Where the hell is the mark
  • shamal
  • shamal's Avatar Topic Author
02 Feb 2016 23:19
#709132
On this rotor , i thought it can be 180° off. I cant find any mark on the lobe :(
1983 kz 550 h
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
Re: Where the hell is the mark
02 Feb 2016 23:45 - 02 Feb 2016 23:47
#709133
shamal wrote: On this rotor , i thought it can be 180° off. I cant find any mark on the lobe :(
The part you are showing is keyed when it goes on the crankshaft - it cannot be 180 degrees out, you should see the T 1-4 mark point to the marker on the timing cover which is screwed to the engine when piston one / four are in the top position.
I suspect you haven't fitted the cover with the timing mark. Let me know if you have a problem understanding this, I can take a photo if required.
Last edit: 02 Feb 2016 23:47 by Bozo.
  • shamal
03 Feb 2016 00:04
#709134
Im referring about this
1983 kz 550 h
  • shamal
03 Feb 2016 00:05
#709135
1983 kz 550 h
  • rrsmsw9999
  • rrsmsw9999's Avatar
03 Feb 2016 02:09 - 03 Feb 2016 02:11
#709138
Attachment IMG_1459.jpg not found
There should be a "TEC" and number "1016"mark on it. The cam lob should point that way.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 03 Feb 2016 02:11 by rrsmsw9999.
  • Bozo
  • Bozo's Avatar
03 Feb 2016 02:24
#709141
shamal wrote: Im referring about this
My bad, my suggestion is to find out which pickup is triggered (by the cam on the part in picture) i.e when on F 1-4 the correct pickup for that coil to plugs 1-4 should be triggered (the cam should point to the correct pickup).
Sorry this is hard to describe.
  • Nessism
  • Nessism's Avatar
03 Feb 2016 02:34 - 03 Feb 2016 02:41
#709144
The base is keyed to the crank but it IS possible to install the rotor 180 degrees out of phase. I know because I did it (somehow). Hopefully someone will confirm this but I think that with the 1-4 T mark pointing up, the rotor points to the left.
Last edit: 03 Feb 2016 02:41 by Nessism.
  • shamal
03 Feb 2016 02:53
#709146
The bike will be able to run with it 180 degrees off?
1983 kz 550 h
  • TexasKZ
  • TexasKZ's Avatar
03 Feb 2016 04:11
#709155
No
03 Feb 2016 04:14 - 03 Feb 2016 04:14
#709156
Nessism wrote: . . . with the 1-4 T mark pointing up, the rotor points to the left.
That's correct. :cheer:
When the pointed end of the rotor passes by the left-hand (9 o'clock) pickup module, a signal is sent to the ignition coil that fires outside cylinders 1 and 4.
When the pointed end of the rotor passes by the right-hand (3 o'clock) pickup module, a signal is sent to the ignition coil that fires inside cylinders 2 and 3.
Good Fortune! :)
Last edit: 03 Feb 2016 04:14 by Patton.
  • rrsmsw9999
03 Feb 2016 04:15 - 03 Feb 2016 04:17
#709157
The lobe of the cam needs to point to the TEC mark. I have done the same 180 and it won't run, probably not your problem as it runs. BTW this is clearly indicated in the Kawasaki FSM. I am not sure I understand your question. At TDC on piston 1 the tming mark should align with the case pin at 1/4. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 03 Feb 2016 04:17 by rrsmsw9999.
The following user(s) said Thank You: shamal
  • z1kzonly
  • z1kzonly's Avatar
03 Feb 2016 06:54
#709179
Seeing your working on it, TRY it both ways. process of elimination. And No it won't fire 180 off.
