kz650 engine won't make full revolution with wrenc
- blink543
29 Jan 2016 18:09
So the engine has been out of the frame and I was gonna set up the timing again while it was out. I was trying to turn the timing nut and it's only making a quarter turn then it stops dead. I don't wanna force anything. Anyone know why I can't turn it? It's in neutral
Adam james
- missionkz
Re: kz650 engine won't make full revolution with wrenc
29 Jan 2016 19:13
If it's not in 5th gear, maybe the cam chain is loose and got stuck/bound?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
30 Jan 2016 02:58 - 30 Jan 2016 02:59
Be sure to check the valve timing.
Removing the ignition plate from the RH end of the crank made it much easier for me to see the timing marks. You need to get the 1-4 pistons at TDC (1-4 T mark aligned with the mark on the cases), then look at the exhaust cam for proper timing. If that looks good then count the pins back to the intake cam.
Last edit: 30 Jan 2016 02:59 by Nessism.
- blink543
30 Jan 2016 03:54Nessism wrote: Be sure to check the valve timing.
You're right yeah I was dumb and tried turning it out of time. A valve was stopping it.
Adam james
- Rockranch
30 Jan 2016 04:19Food for thought...Now make sure that valve(s) isn't damaged. Valves are easily damaged that way depending on how hard you cranked on it while out of time...................................................Mikeblink543 wrote:Nessism wrote: Be sure to check the valve timing.
Vroom-vroom!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
30 Jan 2016 04:26
It don't take much. How did those steering head bearings go? Are they in? :dry:
- blink543
30 Jan 2016 15:47swest wrote: It don't take much. How did those steering head bearings go? Are they in? :dry:
I just put the original ball bearings in
Adam james
