I got a 77 kz650 but it wont go faster then 85
- Willy1803
- peter1958
- Banned
- Thank you received: 198
- Thank you received: 2098
Willy1803 wrote: My bike wont go past 85 mph an sucks down gas like its a truck please help or ill have to sell
If not already done, would first check the crankcase oil for gasoline contamination by sniff-testing and examining its physical condition.
Would also assure that the timing is correct and that the automatic advance unit is properly functioning.
Engine might be running on just three cylinders, or maybe on just 2 cylinders.
Has the water mist spray test been performed?
Could use a common household hand-held sprayer to spray water-mist onto the exhaust header pipes shortly after starting a cold engine to assure combustion in all cylinders. Water spray should sizzle off every header pipe and instantly vaporize.
- Thank you received: 2829
If pods, assure filters are clean and clear and unobstructed.
Assure enrichener lever is OFF (choke lever is pushed down), and that the choke plungers are actually in the down position.
Assure that fuel levels are within spec, and not too high (clear tube test).
Assure muffler is not clogged.
- strum
- Thank you received: 7
sorry kidding..i bet if you follow the advise given youll be supprised with its power
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Points in good condition and gaps set per specs.
Weak contact breaker spring.
Main jet not too large.
Incorrect valve clearances -- when were valve clearances last checked?
Is the throttle fully opening (all slides going to the top)?
Brakes dragging?
Clutch slipping?
Hopefully not a mechanically-challenged novice that just acquired his first motorcycle :ohmy:, in which event, much of the advice will likely be incomprehensible.
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- Thank you received: 2234
Get a genuine Kawasaki Factory Service manual for the specific year and model you have. They come up on eBay pretty often, and some are available digitally. Members here may be able to help. A Clymer manual is better than nothing, but the factory manual is more thorough.
You will need a few special tools, like some metric wrenches, metric feeler guages, and a set of JIS screwdrivers. A good carburetor synchronizing tool will also be needed. Morgan makes a good, though pricey one. Oh, and a pair of high quality torque wrenches. One in inch-pounds, the other in foot-pounds.
Carefully perform all the maintenance and tune up procedures in the order listed in the manual, and you will eliminate a bunch of problems and potential problems.
Back in the 1970s and '80s, Kawasaki never imagined what crappy fuel we would have today, nor did they assume that their products would sit around unused for decades, so the advice given above about crappy fuel clogging the carbs and rusted timing advancers will not be covered in the FSM, but is really good advice. Once you get it all sorted out, a high quality inline fuel filter can prevent a lot of grief.
This may seem a bit intimidating, but I bet you will be pleasantly surprised by the results. When properly cared for, the 650 is a real gem.
- redhawk4
- Thank you received: 64
Otherwise it's basic tune up, valve clearances, timing, spark plugs and a thorough carb cleaning. A good running KZ650 is still a pretty fast bike, mine still amazes me with it's performance, so 85mph should be easily met and exceeded depending on your bravery,
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
