Cam chain tensioner part
  • Madtrout
  • Madtrout's Avatar Topic Author
14 Jan 2016 06:11 - 14 Jan 2016 06:12
#706685
Starting to reassemble the top end on my 1982 GPz750 and I see that I have to take off this rubber piece off (Cam chain Guide Damper) to extract the Cam Chain Guide Shaft. I guess I should replace the rubber bit, but I am wondering if this piece is glued on or just held in place? Any advice would, as always be appreciated, Mark
Attachment IMG_0893.jpg not found
Last edit: 14 Jan 2016 06:12 by Madtrout.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Cam chain tensioner part
14 Jan 2016 06:25
#706686
They are made of rubberized plastic. They get stuck on the shaft. If you are getting new parts, buy new ones, if not a dab of silicon will hold them in place.
The following user(s) said Thank You: Madtrout
  • Madtrout
14 Jan 2016 06:26
#706687
Thanks for the tip, I'll order the new bits today. Mark
  • Nessism
  • Nessism's Avatar
14 Jan 2016 07:21 - 14 Jan 2016 07:24
#706693
Photo diagram E71 in the factory service manual (page 62) details installing those dampers, including where to apply sealer (they SHOULD be stuck to the shaft). I don't think there is any reason to replace them, although doing so won't hurt anything.
Last edit: 14 Jan 2016 07:24 by Nessism.
  • Madtrout
14 Jan 2016 07:30
#706694
Ah, Indeed it does. Thanks for that. I did go ahead and order the parts, cheap enough while everything is apart and the weather is decidedly un-moto. Mark
