material/thickness for transmission cover gasket?
- aenikolopov
13 Jan 2016 09:53
Hi all. I recently had to replace the trnsmission cover on my 1980 kz650. the gasket I purchased on ebay turned out to be made for a slightly different setup, and though it holds oil now, it's definitely not perfect, and in one place in particular, only half of the width of the gasket is sandwiched.
I'd like to make my own gasket to replace this. Can someone tell me what gasket material and thickness I should use?
Re: material/thickness for transmission cover gasket?
13 Jan 2016 09:57
A normal sheet of gasket material would work'
13 Jan 2016 10:28
I can measure a gasket later tonight when I get home but I suspect the thickness is not critical. 1/6" or so should work.
- aenikolopov
13 Jan 2016 11:12I see. Did you really mean 1/6 or is that 1/16"Nessism wrote: I can measure a gasket later tonight when I get home but I suspect the thickness is not critical. 1/6" or so should work.
- aenikolopov
13 Jan 2016 11:23
I've never bought gasket material. I'm trying to find a suitable sheet on Amazon, but am not sure what fits - there are lots of rubber and cork gasket materials.
13 Jan 2016 11:35
Why not just buy another gasket? I've made my own but even with the ball pien trick it's a PITA.
13 Jan 2016 12:37 - 13 Jan 2016 12:38
Just buy the correct Kawasaki gasket and be done with it.
Last edit: 13 Jan 2016 12:38 by 650ed.
13 Jan 2016 12:44aenikolopov wrote:I see. Did you really mean 1/6 or is that 1/16"Nessism wrote: I can measure a gasket later tonight when I get home but I suspect the thickness is not critical. 1/6" or so should work.
Oops, make that 1/16" thick.
BTW, I've made lots of gaskets in the past from gasket paper. It's easy to trace the pattern and cut out using scissors. Use a common paper hole punch for the holes. Beats the heck out of waiting a week for a Kawasaki gasket for a non critical application.
13 Jan 2016 12:56 - 13 Jan 2016 12:56
No argument here, but if he plans to buy the material from Amazon he will still be waiting for the mailman, so he may as well have the gasket delivered. At around $8 delivered it's probably even cheaper than buying a sheet of gasket material from Amazon. Ed
Nessism wrote:aenikolopov wrote:I see. Did you really mean 1/6 or is that 1/16"Nessism wrote: I can measure a gasket later tonight when I get home but I suspect the thickness is not critical. 1/6" or so should work.
Last edit: 13 Jan 2016 12:56 by 650ed.
- bountyhunter
13 Jan 2016 13:25 - 13 Jan 2016 13:28When I made gaskets for my rebuild, I used the Auto Zone best gasket material. I recall it was about .032" (1/16") thick, the material type was N8904 or something like that. It was really good stuff, has even worked perfectly for the valve cover gasket which is typically thicker.aenikolopov wrote: Hi all. I recently had to replace the trnsmission cover on my 1980 kz650. the gasket I purchased on ebay turned out to be made for a slightly different setup, and though it holds oil now, it's definitely not perfect, and in one place in particular, only half of the width of the gasket is sandwiched.
Last edit: 13 Jan 2016 13:28 by bountyhunter.
- KZB2 650
13 Jan 2016 13:51
Dought you'll ever make one as accurate or as long lasting as Kawasaki .....NOS for me.
650ed wrote:Nessism wrote:aenikolopov wrote:I see. Did you really mean 1/6 or is that 1/16"Nessism wrote: I can measure a gasket later tonight when I get home but I suspect the thickness is not critical. 1/6" or so should work.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
