Possible Kz400 big bore pistons.
- 13bravo
12 Jan 2016 13:46
Playing around with my Kz440 and had to remove the piston because of a stuck piston ring. So I decided to go through an old Wiseco catalog I have checking the pin sizes to see if any would come close to the 440, and well turns out nothing for the 440 but the Honda ATC200S has the same pin diameter and compression height as the kz440 piston I have, which translates to it has the same compression height as the 400 engine while having a larger bore. The ATC200S is 65mm standard bore and is available all the way out to 67mm with a domed piston that in the Honda would be 12.5to1, but I don't know what it would be if used in the KZ400. They also have a smaller dome that is 10.25to1 while the standard piston design is a dish, which would be ok for use with a turbo.
I'll get a picture of the 200S piston I have as compared to the 440 piston. I only have an old Sudco dished piston part# 624-031 on the box.
Just something to keep in mind as it may save one of these old bikes from the scrap heap.
1983 KZ440-D
- Nebr_Rex
Re: Possible Kz400 big bore pistons.
12 Jan 2016 16:20
Do you know the combustion chamber volume of the Honda?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 13bravo
13 Jan 2016 16:41
No I don't. I used to have a head but I no longer have it, or else I could have CC'd it. The only major thing that would have to be done to use the piston is between the pin bosses needs to be opened up a little, it is totally doable at least on the Sudco Piston.
1983 KZ440-D
- Nebr_Rex
13 Jan 2016 17:3213bravo wrote: No I don't. I used to have a head but I no longer have it, or else I could have CC'd it. The only major thing that would have to be done to use the piston is between the pin bosses needs to be opened up a little, it is totally doable at least on the Sudco Piston.
Dome shape and height could make it a no go.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 13bravo
14 Jan 2016 13:05
Finally got the camera charged to take some pictures.
Attachment PIC_2856.jpg not found
Attachment PIC_2857.jpg not found
Attachment PIC_2858.jpg not found
Attachment PIC_2859.jpg not found
Attachment PIC_2861.jpg not found
1983 KZ440-D
- 13bravo
14 Jan 2016 13:08 - 14 Jan 2016 13:14
Here are the Wiseco pistons.
www.wiseco.com/ProductSearch.aspx
I've been trying to find a picture of the dome.
The only image I could find is from ebay.
Attachment s-l1600.jpg not found
1983 KZ440-D
Last edit: 14 Jan 2016 13:14 by 13bravo. Reason: added info
- Nebr_Rex
14 Jan 2016 15:16
That dished piston is taller than the domed piston.
Vertical clearance might be an issue with that cast
dished piston for the small end of the con rod.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
14 Jan 2016 15:34
No stock piston to compare with?
14 Jan 2016 15:40
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is available on eBay. There other options as well.
- Nebr_Rex
14 Jan 2016 16:44
Try finding rings.
swest wrote: This is available on eBay. There other options as well.
Try finding rings.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
14 Jan 2016 16:46swest wrote: No stock piston to compare with?
The stock KZ400 piston actually has a taller dome than the KZ440.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
14 Jan 2016 16:47
There's rings listed too. The thing I don't understand is the different type of pistons.
