Oil filter is blocked by the exhaust. KZ750 L3
  • Random KZR User
  • Random KZR User's Avatar Topic Author
12 Jan 2016 10:01
#706436
When changing my oil, I found that the oil filter is being blocked by the exhaust pipe.
  • Nessism
  • Nessism's Avatar
Re: Oil filter is blocked by the exhaust. KZ750 L3
12 Jan 2016 10:29
#706439
Did you loosen the screw and try pulling the cover down? You only need about 1/2" clearance and then you can tilt the cover on an angle to clear the pipe.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jan 2016 10:30
#706440
You can pull out the bolt then take the cover off. I have to do that with my V/H system. Put the new filter in, then the spring, then slide the bolt through.
The following user(s) said Thank You: Random KZR User
