oil filter csr1000
- Kwaker2000
oil filter csr1000
31 Dec 2015 01:10
hi i think i have missed a washer when i installed my oil filter it goes on the top of the spring do i need to drain oil and fit one
Re: oil filter csr1000
31 Dec 2015 02:18
Assuming you used a quality filter that has a fairy thick grommet you don't need to drain and put the washer in, but be sure to put it in on your next oil change. Ed
The following user(s) said Thank You: Kwaker2000
- Kwaker2000
31 Dec 2015 02:28
i used a k&n filter thanks ed ,i think it was stuck to bottom of filter silly me so will have to get another one
31 Dec 2015 02:49
You should be fine until next oil change. The same thing happened to me and I didn't notice the washer was missing until about 10 oil changes later. I was using (and still use) K&N oil filters too. Ed
31 Dec 2015 03:49650ed wrote: You should be fine until next oil change. The same thing happened to me and I didn't notice the washer was missing until about 10 oil changes later. I was using (and still use) K&N oil filters too. Ed
What? :ohmy: Ed using an "aftermarket" part on his 650??? :side: Drinking the K&N koolaid are we?
For the record, I'm using stock Kawasaki filters on my 750. They are cheaper than a K&N and I don't like wasting money.
31 Dec 2015 03:55Nessism wrote:650ed wrote: You should be fine until next oil change. The same thing happened to me and I didn't notice the washer was missing until about 10 oil changes later. I was using (and still use) K&N oil filters too. Ed
I would use Kawasaki oil filters, but I wouldn't know where to buy them at a reasonable price; dealers in my area seem to think they are made of solid gold. The K&N oil filters are $5.16 on Amazon with free delivery on orders greater than $35. Where do you get your oil filters, and how much do they cost? Thanks, Ed
- KZB2 650
31 Dec 2015 05:30
I did the same thing and replaced it recently..... easy to do .... think about a new spring too.... I can't believe how worn at the ends mine was after I really looked at it.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
31 Dec 2015 16:42650ed wrote:Nessism wrote:650ed wrote: You should be fine until next oil change. The same thing happened to me and I didn't notice the washer was missing until about 10 oil changes later. I was using (and still use) K&N oil filters too. Ed
$5.16 works for me. I bought a couple filters from either Bike Bandit or Partzilla last time I ordered and they were about $7/each.
31 Dec 2015 16:49
Just ordered a WIX filter today $7 at OR. They're a little wider and taller. Been using them for 2 years. No problems.
01 Jan 2016 10:58
Genuine Kawasaki oil filter for 650s and others - $7.00
www.partzilla.com/parts/detail/kawasaki/KP-16099-003.html
01 Jan 2016 11:27
