Engine building
  • strum
  • strum's Avatar Topic Author
Engine building
30 Dec 2015 15:11
#704944
Im looking for recommendations for engine building.
Who is close to me ..North Georgia and how much does a complete build cost?
i have a 1980 KZ1000 shaft with 20,000 miles .
I just feel the engine needs gone over . 35 years is a long tome for seals ,bearings, ect..
Not looking to go all out just keep it as close to stock as possible so it can be a solid dependable rider..
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Re: Engine building
30 Dec 2015 15:24
#704946
20,000 miles is still a baby if the engine has had regular oil changes and not been too badly abused. You may want to have someone check it out thoroughly to see if there are any problems, and if none are found just perform a full tune-up. You may be surprised at how well it runs. The KZ engine is pretty robust. My KZ650 has never had the head pulled or any other serious work done, and with about 60,000 miles on it I do not hesitate to ride it anywhere. Ed
  • spdygon
  • spdygon's Avatar
Re: Engine building
30 Dec 2015 15:29
#704948
I'm also from north Georgia...there is a shop next to road Atlanta by the name RSS.....Racing Sport Services.
Friend of mine just jade his z1r engine gone through.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • strum
Re: Engine building
30 Dec 2015 15:34
#704951
650ed wrote: 20,000 miles is still a baby if the engine has had regular oil changes and not been too badly abused. You may want to have someone check it out thoroughly to see if there are any problems, and if none are found just perform a full tune-up. You may be surprised at how well it runs. The KZ engine is pretty robust. My KZ650 has never had the head pulled or any other serious work done, and with about 60,000 miles on it I do not hesitate to ride it anywhere. Ed
I adjusted the valves and have done quiet a bit of maintenance on it right away when i got it.. It does run well and your right about the miles
. If they are actual.. To me the transmission isn't as smooth as i would like and i can tell the pan has been off . That tells me there may have been an issue before. so for me if i would like to have that looked at and if i have to go that far i may as well do the rest..
Blairsville Ga.
  • strum
Re: Engine building
30 Dec 2015 15:38
#704952
spdygon wrote: I'm also from north Georgia...there is a shop next to road Atlanta by the name RSS.....Racing Sport Services.
Thanks ill look em up .. Its good to see a fellow Georgian.. maybe we will meet up sometime.. where ya at?
Blairsville Ga.
  • TexasKZ
  • TexasKZ's Avatar
Re: Engine building
30 Dec 2015 15:59
#704955
Can you be more specific about the transmission? It may be something as simple as a maladjusted clutch cable or a gummed up clutch release mechanism.
The following user(s) said Thank You: PLUMMEN
  • spdygon
  • spdygon's Avatar
Re: Engine building
30 Dec 2015 16:31
#704963
Strum....just PM you
1974 Z1 900 project
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Engine building
30 Dec 2015 16:59
#704965
Kawasaki builds a good motor. Should last well into 100K if taken care of.
Liquid cooled Kawasaki ZG100's have been reported to go to 300K.
Blue 1975 Z1B
Red 2009 Concours 14
  • strum
Re: Engine building
30 Dec 2015 17:18 - 30 Dec 2015 17:22
#704966
TexasKZ wrote: Can you be more specific about the transmission? It may be something as simple as a maladjusted clutch cable or a gummed up clutch release mechanism.
I cleaned,oiled and adjusted the cable.. and adjusted it at the engine. behind the release . It just feels clunky to me when going through the gears. not smooth .. it jumped out of gear once on me but i think i lazy shifted it. I haven't thought about the release mechanism being the culprit. Hmmm
Blairsville Ga.
Last edit: 30 Dec 2015 17:22 by strum. Reason: wording wrong
  • baldy110
  • baldy110's Avatar
Re: Engine building
31 Dec 2015 07:59
#705020
What oil are you running?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Engine building
31 Dec 2015 13:04
#705059
My tranny was clunky until I put in my clutch. You might try taking out the clutch plates, oil them and put them back in. Might be stuck together. I think that's what happened to mine.
