Installing clutch pushrod oil seal 1982 GPz750
  • Madtrout
  • Madtrout's Avatar Topic Author
26 Dec 2015 04:56
#704388
What is the proper procedure for installing the clutch pushrod oil seal? Do you use a light coat of oil or any sealant? Thanks, Mark
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Installing clutch pushrod oil seal 1982 GPz750
26 Dec 2015 06:02
#704394
If it's anything like mine there's no steel inner core. Push it in from the inside. Maybe use some Three bond or the like to help keep it in. I didn't use anything but I'm watching it closely.
The following user(s) said Thank You: Madtrout
