mixed crankcase
- perrineric
Re: mixed crankcase
13 Dec 2015 07:56
Hello ! Most of the main caps were identified with the motor number , on this at least i should be ok !
- PLUMMEN
Re: mixed crankcase
13 Dec 2015 08:38
How many sets of cases are you working on?
The following user(s) said Thank You: perrineric
- perrineric
Re: mixed crankcase
13 Dec 2015 08:47
Hello! i am working on 6 crankcase , i have more but only those 6 may be mismatched
- perrineric
Re: mixed crankcase
19 Dec 2015 11:54
Hello ! Well , bore gauge seem to be the best way therefore, the molding mark are stamped so i am sure there is relation between numbers indicated at least the first one. for exemple 92 stamped on the top must be corresponding with an other case stamped 92 . the second number is never corresponding .It would interresting to know what those numbers means.
thanks !
Eric
thanks !
Eric
