mixed crankcase
  • perrineric
  • perrineric's Avatar Topic Author
mixed crankcase
11 Dec 2015 21:40
#702797
Hello ! i have a large batch of open motor but the crankcases are splitted have been mixed. is there a way to know wich one is fitting to a other one , there is number indicated in the molding just upper the kick shat written like 92/26 and the other part have also un number. does any one know what those number means? do they hould be the same on the lower and upper part ? is there a way to identifie wich lower cranckase is going to wich upper crankcase ?
If somebody could hepl it will be apreciate!
thanks!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: mixed crankcase
12 Dec 2015 05:48
#702808
Pics!
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: perrineric
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: mixed crankcase
12 Dec 2015 06:37
#702814
One hell of a puzzle. :ohmy:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: mixed crankcase
12 Dec 2015 06:57
#702817
After thinking on this, the locator pins are drilled as a set. It might be possible to match halves this way. The outside milled surface should be smooth if they match. I had a guy washing rods for me while I was doing other things. I told him not to mix them up, they are bored as a set. They weren't marked, he walked away with all of them still in a bucket in pieces. I tried to match them by going by the grind marks. I put the engine together thinking I had it right. I fired it up and it sounded like new. It idled then froze up. I should have done it myself but the guy was whining about not having any money. I never made that mistake again. :angry:
  • perrineric
Re: mixed crankcase
12 Dec 2015 08:24
#702831
Hello ! Thanks to every one for helping! I will post pics on monday, I think those small number indicated on inch halves should signified some thing and may help . i found this pic on the net this number i am talking about in the red square for the lower crankcase , the other one is on the top of the upper crankcase at the kick shaft localisation . Should be corresponding both ?
  • perrineric
Re: mixed crankcase
12 Dec 2015 08:29
#702833
Thanks i tried to insert a pic but it do not seem working !
Attachment 299371664_tp.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: mixed crankcase
12 Dec 2015 08:47
#702835
If you're talking about the ones in the circles, they are casting numbers. The one on the top of mine next to the kick start has no numbers in it. I don't think that will help. :(
  • Nessism
  • Nessism's Avatar
Re: mixed crankcase
12 Dec 2015 09:29
#702839
If you have a bore gauge you could use trial and error assembling halves and then checking the crank bearing bores to see if they are round. Once you get a matching pair move to the next set and keep going...
  • perrineric
Re: mixed crankcase
12 Dec 2015 10:18
#702844
Thanks! Some time numbers in this circle are invisible or hard to read!
  • perrineric
Re: mixed crankcase
12 Dec 2015 10:31
#702846
thanks! i have a bore gage! i will try your way on monday and will come back to you thanks again !
  • DFIGPZ
  • DFIGPZ's Avatar
Re: mixed crankcase
13 Dec 2015 05:24
#702928
does that mean main caps mixed up also???
1984 750 Turbo
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: mixed crankcase
13 Dec 2015 05:30
#702930
They'd have to be. :unsure: When the tweekers down the street stole my cases, they didn't get the main caps. All they got was aluminum.
