mixed crankcase
- perrineric
mixed crankcase
11 Dec 2015 21:40
Hello ! i have a large batch of open motor but the crankcases are splitted have been mixed. is there a way to know wich one is fitting to a other one , there is number indicated in the molding just upper the kick shat written like 92/26 and the other part have also un number. does any one know what those number means? do they hould be the same on the lower and upper part ? is there a way to identifie wich lower cranckase is going to wich upper crankcase ?
If somebody could hepl it will be apreciate!
thanks!
thanks!
- Nebr_Rex
Re: mixed crankcase
12 Dec 2015 05:48
Pics!
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: perrineric
Re: mixed crankcase
12 Dec 2015 06:37
One hell of a puzzle. :ohmy:
Re: mixed crankcase
12 Dec 2015 06:57
After thinking on this, the locator pins are drilled as a set. It might be possible to match halves this way. The outside milled surface should be smooth if they match. I had a guy washing rods for me while I was doing other things. I told him not to mix them up, they are bored as a set. They weren't marked, he walked away with all of them still in a bucket in pieces. I tried to match them by going by the grind marks. I put the engine together thinking I had it right. I fired it up and it sounded like new. It idled then froze up. I should have done it myself but the guy was whining about not having any money. I never made that mistake again.
- perrineric
Re: mixed crankcase
12 Dec 2015 08:24
Hello ! Thanks to every one for helping! I will post pics on monday, I think those small number indicated on inch halves should signified some thing and may help . i found this pic on the net this number i am talking about in the red square for the lower crankcase , the other one is on the top of the upper crankcase at the kick shaft localisation . Should be corresponding both ?
- perrineric
Re: mixed crankcase
12 Dec 2015 08:29
Thanks i tried to insert a pic but it do not seem working !
Attachment 299371664_tp.jpg not found
Re: mixed crankcase
12 Dec 2015 08:47
If you're talking about the ones in the circles, they are casting numbers. The one on the top of mine next to the kick start has no numbers in it. I don't think that will help.
Re: mixed crankcase
12 Dec 2015 09:29
If you have a bore gauge you could use trial and error assembling halves and then checking the crank bearing bores to see if they are round. Once you get a matching pair move to the next set and keep going...
- perrineric
Re: mixed crankcase
12 Dec 2015 10:18
Thanks! Some time numbers in this circle are invisible or hard to read!
- perrineric
Re: mixed crankcase
12 Dec 2015 10:31
thanks! i have a bore gage! i will try your way on monday and will come back to you thanks again !
- DFIGPZ
Re: mixed crankcase
13 Dec 2015 05:24
does that mean main caps mixed up also???
1984 750 Turbo
Re: mixed crankcase
13 Dec 2015 05:30
They'd have to be.
When the tweekers down the street stole my cases, they didn't get the main caps. All they got was aluminum.
