Oil pouring from engine top
- rrsmsw9999
Re: Oil pouring from engine top
07 Dec 2015 09:39
Another gasket tip. Soak the gasket in ATF prior to install and it will never stick to any case again. never had one leak over 20 years on various other bike models.
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: Unz
- floivanus
07 Dec 2015 10:37
Neversieze, oil or a glob of grease do the trick as well.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: 750Kruzer, Unz
- 750Kruzer
07 Dec 2015 16:50redhawk4 wrote: Texas has covered the areas where oil leaks occur at the top of the motor. It shouldn't be anything serious, in fact it's a good sign the oil is getting to the top of the engine. The cam end plugs and tach drive all have rubber parts that shrink and harden with old age causing leaks. The valve covers themselves are often pretty lose, I think perhaps the gaskets shrink or something if the bike sits and no oil gets on them, it's not unusual to find some of the bolts are finger tight. You can try retorquing it to the correct figure, but unless it's really loose it sounds like you need new gaskets and seals.
I plan on removing my gas tank and checking the torque of my cam cover bolts (I have a small leak), especially after reading your post, as its not overly involved a novice mech like myself.
1983 KZ750 LTD Twin K1
- JR
07 Dec 2015 17:26 - 07 Dec 2015 17:27
750 Kruger wrote
Be careful and check the torque figure in your kawasaki manual. The figure will be in inch pounds and don't over do it as these holes will strip just as easy as cam cap holes.
Otherwise no problem
Last edit: 07 Dec 2015 17:27 by JR.
07 Dec 2015 17:33
Be sure to use a torque wrench calibrated in INCH pounds. Do NOT use one calibrated in FOOT pounds even if you do the foot lb to inch lb conversion because torque wrenches are not accurate at settings which are lower than 20% of their highest setting. Ed
- Unz
27 Apr 2016 11:07
All done Ed, fired her up, after I had the welding done, and cut a new thread (repaired the exhaust stud I snapped off too haha) hopefully finish it in time for some spring rides
