Muffler system rust & hole in manifold
26 Nov 2015 09:43 - 26 Nov 2015 11:31
What would you do? My exhaust system looks to be in good shape appearance-wise, but it has rust at the manifold & now there's a small hole (approx. 1-2 mm. doh).
Photo of underside of manifold --- the hole is on the top side in the general area of the yellow circle. doh.
Here's a pic of the exhaust system prior to installation a couple of years ago. Although it was in really good condition, it wasn't as nice as the photo indicates. It was used & had some minor surface rust in the usual areas of the manifold, but the rust has gotten worse.
Last edit: 26 Nov 2015 11:31 by martin_csr.
Re: Muffler system rust & hole in manifold
26 Nov 2015 10:49
I'd clean it and weld it. Maybe spray it with Rustoleum. It's on the bottom right?
26 Nov 2015 11:28
Thanks. The hole is on the top side --- the photo is of the underside. The exhaust system seems solid, except for the little hole & the surface rust. I've considered hitting it with a wire wheel to remove the surface stuff, then spray w bar-b-que grille paint. But I'd guess it's rusting on the inside worse. doh.
26 Nov 2015 11:42
I'll bet you're right. It's probably rotting from the inside. Maybe a patch to cover it? Heat might make it worse.
26 Nov 2015 12:13 - 26 Nov 2015 16:13
When I was in college back in the '80's I had an XS400 commuter bike with a rusted muffler. I threw a JB Weld patch on that bad boy and continued to ride it for another 6 months before selling off the bike. A getto repair for sure, but any port in the storm.
Last edit: 26 Nov 2015 16:13 by Nessism.
- peter1958
26 Nov 2015 12:31 - 26 Nov 2015 12:32
Id spray the inside after cleaning it with a rust cleaner then weld it. What do people learn in collage
www.kzzone.com/
Last edit: 26 Nov 2015 12:32 by peter1958. Reason: r
26 Nov 2015 12:39
From what I know about metal cancer is the hole is just the start. It's worse than it looks.
26 Nov 2015 15:53 - 26 Nov 2015 15:53
Yes, that's what I'm worried about. Other than the rusty spots at the manifold, the chrome looks pretty good. I'd like to nip this in the bud before it gets too far gone. In addition to the rust, the insides are probably coated with carbon, so it's probably going to be a pain to clean it up before I can do any kind of treatment. I'm thinking of using bristle brushes & various cleaners to scour the inside, then maybe try an Evaporust treatment, then paint it with bar-b-que grille paint. Or skip the rust-chem treatment & just use the paint. I've had good luck coating the back side of chrome steel parts to deter rust, so maybe this will work on the muffler system as well. ???
Last edit: 26 Nov 2015 15:53 by martin_csr.
26 Nov 2015 16:04
Maybe ness's idea.
- eddiem
- KZR FLAG RELAY CARRIER #63
26 Nov 2015 16:21
How about using a steam cleaner or hot water pressure washer? running it into the pipes. I agree with the evaporust.
martin_csr wrote: Yes, that's what I'm worried about. Other than the rusty spots at the manifold, the chrome looks pretty good. I'd like to nip this in the bud before it gets too far gone. In addition to the rust, the insides are probably coated with carbon, so it's probably going to be a pain to clean it up before I can do any kind of treatment. I'm thinking of using bristle brushes & various cleaners to scour the inside, then maybe try an Evaporust treatment, then paint it with bar-b-que grille paint. Or skip the rust-chem treatment & just use the paint. I've had good luck coating the back side of chrome steel parts to deter rust, so maybe this will work on the muffler system as well. ???
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- ezrider714
26 Nov 2015 17:11
I'd clean1/4 to 1/2 inch around it with a wire brush, Dremel in need be, and braze it up...You can color it the way you want...
The real issue is once rust starts, there's no stopping it, :woohoo: it's just a matter of how much you can slow it down
...... Have went thru a few exhaust systems since 1979...... :ohmy:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
26 Nov 2015 17:39
That might work. Not too hot.
The turkey is working, I'm going to bed.
