PCV Breather?
- CoreyClough
- GPz550 Addiction
PCV Breather?
22 Nov 2015 16:41
Just thinking if any of you have thought about running one or 2 Positive Crankcase Breathers on your engine? Air could go in one way, and out the other? Just a thought.
'85 GPz550(ZX550-A2)
- Tyrell Corp
Re: PCV Breather?
22 Nov 2015 17:17
Hi Corey, there was a guy here that did something with some hose and T pieces to vent the crank breather back to the pod filters. Seems a better solution than the usual hose and beer can catch tank set up.
Re: PCV Breather?
22 Nov 2015 17:44
Kawasaki already installed one.
- CoreyClough
- GPz550 Addiction
Re: PCV Breather?
22 Nov 2015 17:53 - 22 Nov 2015 17:56This could spit oil back into the filters, and into the carbs. Only problem would be if there is too much oil spitting.Hi Corey, there was a guy here that did something with some hose and T pieces to vent the crank breather back to the pod filters. Seems a better solution than the usual hose and beer can catch tank set up.
Could you elaborate on this, unless you are commenting on Brendan's Post above? As far as I know Kawasaki had the breather connect to the bottom of the air box, but I am not aware they used one way check valves. Currently, under the carbs, there is a breather port for venting. I guess just keeping the set up as it is, using that port as a two-way breather instead of trying to control the flow of crankcase pulses is the norm.Kawasaki already installed one.
Last edit: 22 Nov 2015 17:56 by CoreyClough.
Re: PCV Breather?
22 Nov 2015 17:58
Doesn't need a valve. The catch drum recycles oil vapor. Vacuum from the box keeps the crank case vented. On auto's the valves have a habit of getting gummed up.
Re: PCV Breather?
22 Nov 2015 18:03
Yes, that's what I was talking about. What is the goal here?
- Tyrell Corp
Re: PCV Breather?
22 Nov 2015 18:04
The standard set up is venting the oil vapours through the separation chamber under the breather cap, then the gases go back into the airbox. Excess oil blowby will be a problem whatever you do. I'm not sure the need for a check valve.
- CoreyClough
- GPz550 Addiction
Re: PCV Breather?
22 Nov 2015 18:07 - 22 Nov 2015 18:09
It was just a thought rather than to have the oily air go back into the system. The crankcase pulses these gasses. I was just thinking about controlling the flow, that's all. Changed the PCV Valve in my truck, and started thinking about the bike. I don't think using 1 or 2 PCV Valves would be needed. I'll keep my vent as it is.
Last edit: 22 Nov 2015 18:09 by CoreyClough.
Re: PCV Breather?
22 Nov 2015 18:12
On my old V 8 Ford, one bank has a PCV valve after the filter, the other bank has a strained vent drum and goes into the air cleaner before the filter. Always a skid mark on the filter in that area. That's what Bonnie called the marks left on our toilet after a woman used our bathroom. :woohoo: She made her clean it up. :lol:
