Rattling starter clutch. Lose 3 st. clutch bolts.
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
11 Nov 2015 12:28
#698257
2 KZ1000, same problem!
I bought a parts bike, 81 KZ1000 J, it had the same problem like mine 80 KZ1000E, lose starter clutch bolts.
So if you hear rattling from clutch, I suggest buying 3 bolts with allen heads m8x1.25 thread.
Probably red locktite is a good idea. I used JBWeld
96 Yamaha Royal Star
82 Yamaha Virago 920
The following user(s) said Thank You: jeff80kz1000e2
  • jeff80kz1000e2
  • jeff80kz1000e2's Avatar
Re: Rattling starter clutch. Lose 3 st. clutch bolts.
11 Nov 2015 13:49
#698263
Right on, I will check mine. It had been rattling from time to time. Only approx9k original miles bit I figured age was getting to it. Perhaps this is the fix. Thx
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Nov 2015 18:18
#698306
I use a hand impact driver for them.
  • car5car
  • Banned
  • Banned
11 Nov 2015 19:09
#698310
I think most models need 16 mm rotor remover up to 80, then 18 mm.
