piston rings
- blink543
Re: piston rings
06 Nov 2015 17:36jackleberry wrote: ATF = automatic transmission fluid (a very high detergent oil)
MMO = marvel mystery oil (alcohol and wintergreen oil?)
Adding that stuff to the oil? Would that change the viscosity or the ability to lubricate?
Adam james
Re: piston rings
06 Nov 2015 18:11
Is this the bike with the leaky carb?
- blink543
Re: piston rings
06 Nov 2015 18:25swest wrote: Is this the bike with the leaky carb?
Yes the only bike I own
Adam james
Re: piston rings
06 Nov 2015 18:27
Gas in the oil.
- blink543
- jackleberry
Re: piston rings
07 Nov 2015 11:43blink543 wrote:jackleberry wrote: ATF = automatic transmission fluid (a very high detergent oil)
Not if you only add the recommended amount.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- jackleberry
Re: piston rings
07 Nov 2015 11:45 - 07 Nov 2015 11:46blink543 wrote:WHAT?swest wrote: Gas in the oil.
Some carbs overflow fuel into the cylinders when they leak. Fuel dilutes the oil and causes wear and smoking.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 07 Nov 2015 11:46 by jackleberry.
