clutch won't disengage- cant adjust enough?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Re:clutch won't disengage- cant adjust enough?
04 Nov 2015 03:44
#697144
Buy or make another one. One piece this time.
  • punisher11b
  • punisher11b's Avatar
04 Nov 2015 04:05
#697148
Lord_Verminaard wrote: Sometimes it's the small things that get you. Although if I were the one that originally tore the bike down (or mostly torn down as I received it) then I would have noticed that right away. Buying someone else's unfinished project might seem like a good deal but I've missed out on a year and a half of riding just trying to get this "project" in a usable state. :S
There really needs to be a test before you can buy a screwdriver or wire strippers! Some people just shouldn't be aloud to try and fix things. I'm still finding wire nuts in my 440 wiring harness from the PO! :laugh:
- good luck
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Nov 2015 04:56
#697152
Some people shouldn't be allowed to own motorcycles.. :lol:
  • jackleberry
  • jackleberry's Avatar
Re: clutch won't disengage- cant adjust enough?
04 Nov 2015 07:03
#697179
Heh. Even running vehicles are full of surprises and mysteries left by the PO. A basket case is... rarely a good deal.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • missionkz
  • missionkz's Avatar
04 Nov 2015 12:19
#697223
Ah, but the sign of a true craftsman is how well he hides his mistakes or fixes those of others!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Nov 2015 14:59
#697248
One of my competitors has a logo saying, I fix what your husband broke. Wish I'd thought of that. :whistle:
  • Stockton350
  • Stockton350's Avatar
04 Sep 2022 09:06 - 04 Sep 2022 09:07
#873322
I'm years late to the party but wanted to share my experience with this identical issue for anyone dealing with this in the future. I had the issue of my cable seemingly too long no matter what I did, like inches too long. It didn't make sense because the bike had been ridden and I could see by the rust where the cable had been originally adjusted.
Long story short, I think the issue comes because the clutch spring arm (the thing that you attach the clutch cable into and secure with a cotter pin) is oriented incorrectly. If you imagine the cover to be on the bike, that arm actually needs to be pointing toward the rear of the bike. When installing the arm, it's not apparent where it should be pointing. Initially I had it pointing toward the front of the bike. That's what creates all the slack.
So... Readjust all the screw adjusters so they're back to where they were based on the rust lines. Slide in the adjuster arm so it's sitting over the three ball bearings BUT facing towards the back of the bike. This should take up the mystery slack that was on the cable.
It should fully seat on the bearings, sitting flat in the cam. The idea is that it's sitting flat now but when the cable pulls it, the assembly will rotate on the cam and lift up, applying pressure on the clutch rod.
Carefully reassemble, making sure everything stays in place as you reinstall the cover and cinch it down tight to the engine case. There must be no space between the cover and case. Hope this helps someone. Good luck.
1975 CB125 | tinyurl.com/jds9l7q
1976 CB350
1978 KZ200 | tinyurl.com/j3odxo8
Last edit: 04 Sep 2022 09:07 by Stockton350.
  • menno_kz700
  • menno_kz700's Avatar
27 Mar 2026 13:39
#922581
i'm also years later on this topic but perhaps helpful for anyone: I've a kz700. After disconnecting the clutch cable and having cleaned and put back together the clutch release, following the steps of the service manual,  the clutch release mechanism did not touch the push rod anymore. it seemed my cable was suddenly centimetres too long... after putting it back together a few times I noticed the adjustment screw in the bracket cover should not be adjusted by turning inwards by turning clockwise but by turning counter clockwise!
As this was not defined in the manual for my model specifically it took a while before I found out... hopefully useful for someone in the future!
